Excursion Sport Build
Old Jan 5, 2021 | 09:11 AM
  #151
FinnishStroker's Avatar
FinnishStroker
Originally Posted by brokestroke
Got out for a bit, real heavy snow.
I was inspired by those pics:
Old Jan 6, 2021 | 05:51 AM
  #152
brokestroke's Avatar
brokestroke
Unfortunately, almost all of our snow is melted.
Old Jan 6, 2021 | 06:31 AM
  #153
FordTruckNoob's Avatar
FordTruckNoob
Hey @brokestroke , how's the compound coming along?
Old Jan 6, 2021 | 07:40 AM
  #154
brokestroke
Its going.
Question about the vacuum canister mounted on the passenger side under the hood. Does the canister run the heat functions as well as the vacuum assist hubs?
Old Jan 6, 2021 | 07:43 AM
  #155
FordTruckNoob
Its going.
Yup. It does. That should be easily relocated with a bit longer vacuum line though.
Old Jan 6, 2021 | 07:45 AM
  #156
ESwift's Avatar
ESwift
CNCFAB
Its going.
Yes it does, how do I know, mine got ripped out along with liner wile backing up plowing and front mud flap caught tire. Now only defrost.... Guess I will reinstall when or if I get time.
Old Jan 6, 2021 | 08:00 AM
  #157
SkySkiJason's Avatar
SkySkiJason
OUCH.
Unplug your vac pump so it doesn’t burn up running all the time.
Old Jan 6, 2021 | 08:07 AM
  #158
ESwift's Avatar
ESwift
CNCFAB
OUCH.
I did right away, almost lost that too, phew..cause it was almost new
Old Jan 6, 2021 | 10:21 AM
  #159
FinnishStroker
You'll need only defrost while plowing..
Old Jan 6, 2021 | 10:55 AM
  #160
ESwift's Avatar
ESwift
CNCFAB
Toes get cold
Broke sorry to deviate from you sweet build.
Back on track now fellas
Old Feb 16, 2021 | 05:34 PM
  #161
brokestroke
Hey guys, getting back to working on this truck again. Just pulled it into the shop and have it defrosting.
First things first. The damn fuel bowl drain valve on this truck leaks like an SOB. I have replaced it 3 times in 4 years. Each time it is fine for a while and it will start back up leaking. Obviously I could have tried swapping the o-rings but for ease I just replaced it each time with a Dorman. Well this time it was only good for about a month and it started leaking again. Are the "after market" fluorosilicone o-rings that great compared to stock? This valve was leaking bad so I put a piece of hose with a plug in it on the drain spout and hose clamped it. Now its leaking under the yellow tab and the whole valve is oily.
Thinking about these.
https://www.dieselorings.com/1999-20...ts/12-001.html
Old Feb 16, 2021 | 10:08 PM
  #162
FinnishStroker
You should be good with those orings.
My fuel bowl is leak free,previous owner did the drain valve orings.
How's the compounds processing ..?
Old Feb 17, 2021 | 06:11 AM
  #163
SkySkiJason
I’ve put the upgraded o-rings in trucks since they came out (over 10yrs ago??)) and literally never had one leak again.
The rebuild kit is like $7. I keep a few in stock and often replace them as PM these days.
Old Feb 17, 2021 | 06:40 AM
  #164
FordTruckNoob
Post up some pics and videos of the other project that distracted you from the Ex man. I'm curious.
Old Feb 17, 2021 | 06:56 AM
  #165
brokestroke
Good deal, going to order a couple sets of o-rings.
Have a list of things to fix on the truck right now. The front blower motor isnt work and it is terrible in this cold weather with rear heat only.
Luckily the super cold weather has missed Michigan for the most part thanks to Lake Michigan. Although it is -1 F this morning. The truck has atleast 1 bad glow plug and it shows. The GPCM throws a CEL and it smokes, stalls and lopes pretty hard in the morning (never plugged in). Got it in the barn warming up for the following.
Drain Valve fix
Heater fix
Replace glow plug(s)
Replace up-pipes
Install 1.0ar with larger WG
Or skip the last 2 steps and make another T4 kit?
