Valve Spring micrometer
Old Aug 7, 2020 | 10:11 PM
  #91
oldbird1965's Avatar
oldbird1965
Doing good, thanks for asking. I bet you are getting excited, I remember the feeling well.
Old Aug 8, 2020 | 04:34 PM
  #92
fordman67's Avatar
fordman67
Ooohhh aaaahhh das purty!!!
Gotta love the smell and sight of a fresh charger!!!
Old Aug 8, 2020 | 09:15 PM
  #93
MJ79's Avatar
MJ79
Oh yeah hopefully next weekend will be install time.
Old Aug 13, 2020 | 07:25 PM
  #94
MJ79's Avatar
MJ79
Well the kit showed up, and it looks great. Going to paint some stuff with VHT flamefroof paint, and wrap the down pipe.
Old Aug 13, 2020 | 09:53 PM
  #95
oldbird1965
**** for sure! lol
Old Aug 13, 2020 | 09:55 PM
  #96
MJ79's Avatar
MJ79
Originally Posted by oldbird1965
**** for sure! lol
Good evening Glenn. Just my luck the next 7 days are all triple digit heat, but I'll chip away at it.
Old Aug 13, 2020 | 10:17 PM
  #97
oldbird1965
Yep, that stuff is to hot to handle. Triple digit is tough, even in the Black Hills of SD its been in the upper 90's!
Old Aug 13, 2020 | 10:19 PM
  #98
MJ79's Avatar
MJ79
Hopefully this heat wave breaks soon. I'm ready to get this t4 done.
Old Aug 14, 2020 | 08:01 AM
  #99
TheFecalFanatic's Avatar
TheFecalFanatic
I'm green with envy over here.
I've all but resigned myself to getting drenched in sweat down here in FL during the summer and having a big shop fan going and constantly drink water is the only thing I can think of to deal with it. It's miserable but doable for a couple hours. Anything past that is asking for trouble.
Old Aug 14, 2020 | 08:29 PM
  #100
MJ79's Avatar
MJ79
Got some painting done this afternoon.
Old Aug 16, 2020 | 05:13 PM
  #101
kmjone00's Avatar
kmjone00
Thanks for sharing photos, looking forward to seeing it come together.
I am curious, can you share what kind of fuel setup you're using? Could not remember from previous threads and posts. I am interested in seeing how fuel lines route around the T4 pedestals (CSD vs Irate vs stock turbo pedestal). I want to do e-fuel soon, and maybe, one of these days, upgrade to a T4-style turbo. Want to make sure whatever fuel setup I go with the supply lines will route around both factory and T4-style turbo pedestals okay. Whenever you get to that point would you mind sharing some photos please? Thanks much.
Old Aug 16, 2020 | 05:59 PM
  #102
MJ79's Avatar
MJ79
I'm running Marty's diesel efuel kit. The rear feeds are stock going into a custom block. Carson said it should fit under the pedestal no problem. I talked to Marty about changing the rear feeds, but he said there isn't much of a gain. I will share as many pictures as possible. I will definitely get you pictures of the feed lines. Just came in from working on it actually.
Old Aug 16, 2020 | 06:04 PM
  #103
MJ79's Avatar
MJ79
Got the mock up and turbo clocked today. Next will be wrapping the up pipes and down pipe.
Old Aug 16, 2020 | 06:45 PM
  #104
kmjone00's Avatar
kmjone00
Thanks. Mocking the turbo up...that looks like a really fun part.
Yes I recall Marty uses a custom block into the stock banjo bolt and supply lines. While I like that approach, I assume it would only work with CSD's kit as I assume Marty's block would be in the way of Irate's drain. This is the kind of thing I'm trying to plan ahead for now. Thanks again for sharing.
Old Aug 16, 2020 | 06:52 PM
  #105
MJ79's Avatar
MJ79
The main reason I went with the CSD kit is I didn't like the oil feed and drain on the Irate kit. Probably nothing wrong with it, but I feel better with the CSD system.
