Valve Spring micrometer
Old Jul 9, 2020 | 08:23 PM
MJ79's Avatar
MJ79
Originally Posted by Hit Man X
I have a lot of info in my thread about when I did them. Worth a look.
Your thread is a really good one, but didn't remember seeing much on the micrometer.
Old Jul 9, 2020 | 08:25 PM
MJ79's Avatar
MJ79
Got the headstuds done on the driver's side. Had to rock it to get the two rear most studs in. Had to move the power steering pump for the very front one.
Old Jul 9, 2020 | 09:55 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
I probably purchased whatever the other chaps recommend. Using the mic is the only way to do the springs as far as I am concerned. My truck revs SO much better it is not funny. Definitely takes a bit of math to have the springs at the correct installed height...No8 was a real *****.
Old Jul 9, 2020 | 10:00 PM
MJ79's Avatar
MJ79
Lol yeah I'm dreading number 8 as well. Probably number 7 also.
Old Jul 9, 2020 | 11:29 PM
fordman67's Avatar
fordman67
Rock on man!! Moving along for sure!!
Old Jul 10, 2020 | 08:00 PM
MJ79's Avatar
MJ79
Drivers side is done. Took .045 at every valve, so not too bad. I think if I have to do this again I will pull the motor.
Old Jul 10, 2020 | 10:10 PM
oldbird1965's Avatar
oldbird1965
Saving the best for last? lol I've done it twice now and don't want to do it again!
Old Jul 10, 2020 | 10:13 PM
MJ79's Avatar
MJ79
Lol yep the passenger side ought to be a real treat I'm sure. Sucks you had to do it twice. The new motor is holding up pretty good though yeah?
Old Jul 10, 2020 | 10:28 PM
oldbird1965
Yes, the old Jasper has 16K or so on it and its running good. Its just sitting around this year though, I feel bad so I go for a ride once in awhile. Pretty funny!
Old Jul 10, 2020 | 10:31 PM
MJ79's Avatar
MJ79
It will be nice when things get back to normal. The truck is getting a nice break though lol.
Old Jul 11, 2020 | 07:48 PM
MJ79's Avatar
MJ79
Well passenger side is done. Will put it all back together tommorow.
Old Jul 11, 2020 | 08:28 PM
Hit Man X's Avatar
Hit Man X
Thumbs up
Good deal, I am curious how you will feel the difference in RPM capacity.
Old Jul 11, 2020 | 08:32 PM
  #28
MJ79's Avatar
MJ79
Im pretty curious as well. Just put in 238/100 injectors a couple weeks ago, and while detuned it made a huge difference. Pretty happy every cylinder took .045 of shims.
Old Jul 11, 2020 | 10:55 PM
  #29
strokin'_tatsch's Avatar
strokin'_tatsch
What did your installed height end up at with the seal installed? Assuming you're doing Comp 910s? I like 1.750" for 910s, but up to 1.780 is fine for most below 55psi boost/drive pressure. You shouldn't notice much from the springs aside from it wont bend pushrods or break rockers everytime you try to play around with it if they're set up correctly.
Old Jul 11, 2020 | 11:11 PM
  #30
MJ79's Avatar
MJ79
1.800 with out the seal. The micrometer didn't fit over the seal. Yes it was Comp 910s. If my math is right that equals 1.75 with the seal hopefully.
