Valve Spring micrometer
Old Aug 28, 2020 | 05:54 PM
  #166
MJ79's Avatar
MJ79
Pretty good low rpm manners as well on some logging roads. Overall very happy with the way it turned out.
Old Aug 29, 2020 | 01:15 AM
  #167
fordman67's Avatar
fordman67
Sweet!! I'm stoked that egt was good. You just can't deny how well getting rid of that stock charger is.
Rock on!
some beautiful scenery it looks like too!
Old Aug 29, 2020 | 09:28 AM
  #168
MJ79's Avatar
MJ79
Rock on!
Yeah there is a night and day difference. I touched 1350 with out towing with the stock turbo. Most of the trip it was 950 yesterday. It's crazy it was way louder with the stocker also. More powa and less heat. You can't beat that.
Old Aug 29, 2020 | 06:18 PM
  #169
oldbird1965's Avatar
oldbird1965
I'm glad its working out for you! Controlling EGT's is the hardest thing to accomplish on this trucks! Looks like a nice place to visit and get your sanity back.
Old Aug 29, 2020 | 06:29 PM
  #170
MJ79's Avatar
MJ79
All was well till this afternoon. The Walbro gsl392 chit the bed. Looks like my stay has been extended lol.
Old Aug 29, 2020 | 06:35 PM
  #171
TheFecalFanatic's Avatar
TheFecalFanatic
These results only make me that more excited to try out the 363/74/.91 on my truck when that time comes. Hopefully this winter.
Old Aug 29, 2020 | 06:39 PM
  #172
oldbird1965
Oh no, that's not good! They are suppose to be good ones. I put mine on so long ago and can't remember what pump I have. I have two spares and I don't know what they are either, lol. Getting to old I guess.
Old Aug 29, 2020 | 06:40 PM
  #173
97-psd's Avatar
97-psd
Sorry for your luck, the Walbro seems to die at the worst times. I changed to the Bosch and was surprised how much quieter it was and I can get one at any parts store. Good luck on getting a new one
Old Aug 29, 2020 | 07:03 PM
  #174
MJ79's Avatar
MJ79
Managed to get my spare and it was no good as well. Just ordered one from Amazon. It was great till it wasn't lol.
Old Aug 29, 2020 | 07:05 PM
  #175
MJ79's Avatar
MJ79
How hard was the switch? I think I would have to change some parts on my fuel system. Right now not much of a possibility unfortunately.
Old Aug 30, 2020 | 07:37 AM
  #176
BuddyBarnes's Avatar
BuddyBarnes
I know this is going to sound stupid but check the power to the pump. I thought my pump was bad and changed pumps ,no work. I did not check basics. Fixed wire and all was well. I did a lot of work for a simple fix.
Old Aug 30, 2020 | 08:39 AM
  #177
MJ79's Avatar
MJ79
Unfortunately the power is good. I did do that once before though.
Old Aug 30, 2020 | 09:24 AM
  #178
97-psd's Avatar
97-psd
My fuel system is a DIY setup so “results may vary” but my change was pretty simple from what I remember. Here are the changes I made
1. The Walbro used an isolator sleeve but the Bosch didn’t have one. Luckily they were about the same size so I just used the Walbro sleeve on the Bosch.
2. The Walbro had two threaded ports but the Bosch had a barbed style port on the inlet for push lock fittings and a thread port for the outlet. I am using barbed fittings, so I just slide the inlet hose over the barb and clamped it. By dumb luck the outlet of both pumps were the same thread so I just swapped fitting from the Walbro to the Bosch.
3. I used ring terminals for the electrical connections. I think the positive and negative terminals “may” have been on opposite sides, but I am not certain. It was easy since I don’t use any special connectors or anything. If you use a special connector or clip you may have to sort that out.
It was easier than I thought it would be. Mine also crapped out while I had a trailer in tow. I first thought I had a plugged filter as it would run but would starve when under a load. I made it home but I was being very gentle with it. Good luck on getting it fixed. If you need any pics just let me know and I can try to grab some for you
Old Aug 31, 2020 | 09:14 AM
  #179
fordman67's Avatar
fordman67
I'm honestly surprised. The only issue I ever had was it blew the fuse one time long ago.
I think a new spare for the tool box may happen someday just in case.
Old Aug 31, 2020 | 11:00 AM
  #180
MJ79's Avatar
MJ79
For now I'll probably just order another Walbro. Just need to keep it and the tools in the truck to change it out. I haven't dropped the tanks, so there could be something in there causing the problem. Tempted to do a 38 gallon in the rear and get rid of the selector and midship tank.
