Mercury M350 build thread
Old Nov 13, 2020 | 10:05 PM
  #151
Fomoko1's Avatar
Fomoko1
Nice work John.
Old Nov 14, 2020 | 06:02 AM
  #152
JJF20's Avatar
JJF20
Looks good John. Good thinking on the ‘rolling’.
Old Nov 14, 2020 | 10:30 AM
  #153
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
Looks good John!
Old Nov 14, 2020 | 11:18 AM
  #154
Scndsin's Avatar
Scndsin
I have to replace the timing chain cover gasket on the pickup to stop an oil leak so chaining out the gears and chain while at it then scrubbing away all the oil residue that seems to be everywhere under the hood..
Hi John. You're about to embark on the small block hell highway, waterpump/front cover bolts.
One the really the long ones, coolant and all the crap it carries leaks into the open spaces the bolt passes through and solidifies into concrete.
To avoid breaking them off in the block, strongly recommend cutting/grinding the heads off.
Even then the accretion will probally be such as to make it impossible to pull cleanly off the cover & sometimes the pump.
I use the biggest safety pin I can find straightened out, Deep Creep & soft faced hammer. Dig, spray, bang repeat.
Took me 3 days on the autopsy of chapter bud Thomas's 5.8 to pull cover with out one broke in block or cover damage...
And that's on a stand. Good luck.
Old Nov 14, 2020 | 01:12 PM
  #155
56panelford's Avatar
56panelford
I think I should be okay Dave, pretty much all those bolts have been replaced when I changed the pulley system and put a new water pump on it. Looking back I don't no why I didn't change the cover gasket at that time. Now that I have the bullet dislodged from my brain I'll go through the agony now..lol
Timing chain cover gasket was the only one I didn't change
Old Nov 14, 2020 | 03:34 PM
  #156
Scndsin's Avatar
Scndsin
My BAD, was thinking the 96...
Old Nov 14, 2020 | 04:16 PM
  #157
56panelford
I'll get to you when that happens..
Old Nov 22, 2020 | 03:11 PM
  #158
56panelford
Thought I'd clean up the pitted letters I have and looking into a kit to restore the finish on them
Old Nov 22, 2020 | 03:27 PM
  #159
abe's Avatar
abe
They look good, John. How'd you get the pits off?
Old Nov 22, 2020 | 03:38 PM
  #160
56panelford
Sandblasted and then sanded by hand, they need to be re-chromed but I'm looking at getting a kit the might allow me to refinish them myself..
Old Nov 23, 2020 | 06:27 PM
  #161
JJF20's Avatar
JJF20
Hi John, those letters turned out pretty nice. I’m curious to see what the kit is.?
Old Nov 23, 2020 | 06:55 PM
  #162
wpnaes's Avatar
wpnaes
Caswell’s?
Old Nov 23, 2020 | 06:58 PM
  #163
56panelford
I haven't got it yet..that kit is more than I intend to get into, I'm just looking into a copper/nickle plating kit. All I intend to do is get the letters presentable to look at without all the pitting. If all else fails I have some chromed plastic stick on letters..
Old Nov 23, 2020 | 07:03 PM
  #164
abe's Avatar
abe
John, you may find your self on the cusp of a burgeoning side business.
Old Nov 23, 2020 | 07:15 PM
  #165
JJF20's Avatar
JJF20
Originally Posted by wpnaes
I didn’t know you could do this at home... now I want to chrome everything!
