Why Ford
Old Apr 11, 2020 | 05:18 PM
  #121
helifixer's Avatar
helifixer
Originally Posted by doc7string
Thank you for your thoughts. I must admit, I would prefer the diesel (rather have too much than too little) but I don't want to be foolish either. My average daily drive is 32 miles each way, with 1 or 2 10 mile drives in between. Its mostly highway, traffic for about half of the trip and then 70 mph the rest of the way.
with that info i would go diesel, but that is me. when looking for a truck I could have gotten "by" with another F250 (see the pic in my signature) that is my '97 F250 at 27,000 lbs. does it do it? yes! Is it safe? the way i drive probably. will I do it again after towing that load with my F450? never.
When I was looking I went with the F450 over the F350 because of the turning radius and the knowing it won't be overloaded.
Old Apr 11, 2020 | 05:35 PM
  #122
mtnguy's Avatar
mtnguy
I tried out a 2017 Ram Cummins (and Chebby Dursmax) before I bought my 2017 F350 Lariat CCSB 6.7.
The Ram seemed to hesitate even under light acceleration from a stop. The flip up towing mirrors are terrible. The ride was rougher than the Fords. The dash buttons seemed random, with the engine brake particularly hard to locate.
I have never regretted getting the F350.
Old Apr 11, 2020 | 06:19 PM
  #123
2020Tremor's Avatar
2020Tremor
Would the 7.3 be able to tackle big hills and high elevations gracefully with the trailer I noted (Sandpiper 389RD) or heavier like the Paradigm Alliance 365RD (39' 10", GVRW 16800, pin weight 2784)? I am thinking the latter is getting to be too much for the payload of a SRW so maybe a moot point. Back to the diesel for a moment, I could have my wife drive it when I am not so that the mileage could be closer to 20 or 25k/year. This would save miles on her vehicle as well. Just some thoughts that may or may not change your opinion.
From my research the 7.3L with 4:30 gears should be able to handle it but the diesel will do better when you start getting in the higher weight class, plus have a exhaust break.
A friend of mine bought a 2020 6.7L CCLB SRW a few months ago and is it impressive. No question it won’t struggle with your load. Despite being impressed with the Diesel I wound up ordering the 7.3L. All the towing tests I have read and watched on it were positive other than being thirsty. I do not put a large amount of miles per year and only 50% is towing so would take forever and a day to recover the extra cost. Another big factor that played in to going 7.3L is, in a CCSB the 7.3L gained around 600Lbs of payload over a similar equipped 6.7L F-350. May be a moot point on CCLB since not sure the 12.4K GVW is available for the 7.3L.
Old Apr 11, 2020 | 07:43 PM
  #124
doc7string's Avatar
doc7string
Originally Posted by scottz99
Doc, did you decide on the John Deer or the Kubota? I think either will pull your 5th wheel just fine!
Ha Ha. Mahindra!
Old Apr 11, 2020 | 07:48 PM
  #125
doc7string's Avatar
doc7string
If it wasn't for the difficulties DRW would cause me in every day life, the 450 would be high on my list for exactly that reason. Unfortunately, parking at work would not only be painful but often impossible as finding two spaces side by side is frequently impossible.
Old Apr 11, 2020 | 07:50 PM
  #126
doc7string's Avatar
doc7string
Originally Posted by 17 Oaks
Concur!
You bring up a couple of KEY point in towing: Spread the load and LEVEL your rig.
Doing these 2 will assist in mitigating some pin weight yes.
First spreading the weight, not easy to do and you are flying blind so to speak so mitigate just spread the loads in the area of use. Use all the cabinets in the kitchen. Keep as little as possible in your black/grey/fresh water tanks.
LEVEL: This is EXTREMELY important yet few bother with it. Put a sprit level stick on just above and centered on your 3 trailer wheels on each side. Procedure: Take a sprit level and place against the outer wall and centered between the tires when it levels, draw a line about 2 in. do on both side of the trailer. Stick a sprit level (Wall Mart, 2 pack about $3 bucks) on the line.
When you load onto the bed of the truck you are going to need from 4-6 inches of clearance between the bottom edge of your truck rail bed and the 5th wheel. that is your co-wittness point. Level up the 5th wheel ones truck rail and insure or do your best to level up at the 2 rear wheel sets.
I would shoot for 6 in vertical clearance and adjust from there. To much down on the rear wheels were lead to premature tire wear, suspension wear, wheel bearing wear and brake wear increased PIN wt. Weight to the rear wheel set will do same only on the rear decreased pin weight.
DO your best to = the truck-wheel leveling and only compromise if you must.
I figured it wouldn't be as easy as I hoped. Thank you for presenting reality to me.
Old Apr 11, 2020 | 07:52 PM
  #127
helifixer's Avatar
helifixer
there a few around here (homedepot) not to mention any company names that I have to take 4 parking spots.
Old Apr 11, 2020 | 08:07 PM
  #128
doc7string's Avatar
doc7string
Everyone's opinions are great. I must be honest, I asked the original question hoping that you guys would convince me that I want the Ford (simply because the popular internet consensus is Ford is more reliable and the dealerships are typically better at fixing things when necessary). I have been more convinced toward Ford by this forum than toward Ram on the Ram forum. In addition you have pointed out many subtle things (mirrors, rear mid seat... that I would not have realized based on test drives). Thank you. Unfortunately, I now have to tackle gas/diesel. It is a fun problem to have, and I expect that you guys will help me through that as well!.
Old Apr 11, 2020 | 08:08 PM
  #129
doc7string's Avatar
doc7string
OOF. I would have a lot of haters if I did that.
Old Apr 11, 2020 | 08:51 PM
  #130
helifixer's Avatar
helifixer
I go to the absolute back of the parking lot if I am driving the big truck.
Old Apr 12, 2020 | 06:13 AM
  #131
17 Oaks's Avatar
17 Oaks
I am a N 40 Parker. IOW I park about as far away as I can that allow me to be left alone and leaves LOTS of space. Done this all my life...drives me crazy for people in their cars to sit and block the lanes waiting on a parking space next to the front door and not talking handicapped either. I have seen people sit there and are still there when I come back from shopping 30 min later. I usually park in the Remote or spill over lots in the far corner.
Old Apr 12, 2020 | 07:07 AM
  #132
Under-Pressure's Avatar
Under-Pressure
A srw 7.3 CCLB F350 can be spec’d with a 11900 lbs GVWR package.
62KR
Apr 12, 2020 09:30 PM
LSchicago2
Dec 5, 2011 11:26 AM
Smokin_cache
May 28, 2011 11:20 AM
SweetEightysFord
Mar 13, 2008 06:21 AM
joe_lemon
Aug 12, 2001 01:08 PM
