Why Ford
I do apologise for impertinent post, and welcome you to the forum.
Even with your update in regards to driving distance and frequency, I still couldn't recommend the diesel over gas.
It literally has been beaten to pieces, the diesel vs gas debate, and unless you tow often and heavy, or drive 50000+ miles a year, diesel will end up costing more.
I would not want to keep a diesel truck till 250000 miles, assuming you drive the typical 15000 miles a year. Time wreaks havoc on the many ancillary fuel and emissions lines and seals needed for the diesel.
There is no debate on diesel vs gas, if so then answer please: Which is better, 30 06 or 12 ga shotgun? Corvette or Prius...you guessed it, they are different and so is the use and application. I have a Truck Camper tilting the scales towards 6000 lbs in the BED of the truck and I pull a 4000lb trailer, for 19,200 lb loaded. This WHY I have a diesel instead of a gasser, nothing to debate. Those that try to debate apples and oranges which tastes better are not debating, just arguing over which flavor they each like.
Keeping any modern car for 16.7 years and 250k miles will result in a lot of stuff going bad be it diesel or gas.
By the way, there is a guy on here who has a SD, I think a 17, with 436,XXX mi on it with not major issues. He is a rocket driver, fast haulers. He posted a pic of his dash and mi. IIRC it was a F 350.
As for Doc7 I do not believe his 41 ft 5th wheel numbers will be the same as he posted when he loads out. My Cedar Creek 34 ft was well over the numbers he posted for his 41 he is looking at. Not calling him untruthful, but like the sticker on my truck camper 'As built' 4310 lb, but loaded out with wife and dogs for week long I am around 5700 lbs.
For my belief that he is going to tow/haul far more weight I think the diesel is the best long term approach. IF his load numbers are what Doc7 said then you are in gasser space...
I do need to drive it more to get the mileage of the warranty close to the calendar time of the warranty.
I'm not here to give you any advice concerning the diesel/gas or F-150/250/350/450 choice. I currently have a Super Duty on order but is currently in quarantine until the Kentucky plant starts again. Like you, I have been on this site for a bit looking for advice from those who have the knowledge to make an educated decision. Back in the day, when I ordered my 2000 F-150 with the 5.4 engine, someone recommended I go to a Super Duty with the 7.3 diesel engine because I was in the military and moved around a lot. I had told him I don't need such a big truck and don't really need it. I'm very conscious how I spend my money and debate the spending on assets or liabilities all the time. Now fast forward to today... My F-150 did everything I asked her to do and more. With a little over 140K on the clock, she still is strong but burns a little oil. Hindsight, I should have just got the Super Duty and would most likely have it to this day. In the future, I currently plan to pull a tailor or a 5th wheel but don't know which. I will buy the trailer/5th to fit my truck and not the other way around. When I told my folks, I plan to buy a 1 ton, they asked "what the hell do you want to do with that?", I said, "anything I want." The new diesel emissions stuff has me worried, but I see plenty of older Super Duty diesels running around my area with the current emissions. Is this more of a want than a need? Probably. I'm I making up for the mistake of not getting a Super Duty in the past? Maybe. In the end, I'm in a different position now than in the past and if the Super Duty is the wrong decision, I’ll just trade it in for something else. Now if the F-450 came with different rear gears, that is one heck of a truck!!
Now that I wasted your time by rambling and not giving advice, I wish you the best and thank you for your service!
3955 is base wt for my truck camper
4372 is 'as built' wt for my TC
My loaded truck-only wt is 9460 lbs
My ruck with TC is 15180
15180 - 9460 = 5720 lbs or a 1348 lb difference between As Built wt and as loaded for vacation wt.
Take away with a 41 ft 5th wheel you may well end up with more wt on the 5th wheel and the pin that the chart states. I am 1300 lb over and my Truck Camper fits in the bed of the truck. Of course you may not, all the dishes are just paper plates and plastic spoons, wife packs one can of beans per day...LOL you get my drift.
Your a Doc and I am an engineer who career was MISSION CRITCAL architectures, if it went down it costs in the $M's on day 1 and got worse from there. So my bias is to over build to prevent failure due to its catastrophic results...thus: If only I knew then what I know now, my first truck would have been a F 450. I would have bypassed the world of F 350's completely and saved a whole lot of $$$
Anyhow I am NOT trying to convince you, but rather get you to consider the situation and project your needs forward and see if they still meet the ability and capability of your tool set...truck.
Doing these 2 will assist in mitigating some pin weight yes.
First spreading the weight, not easy to do and you are flying blind so to speak so mitigate just spread the loads in the area of use. Use all the cabinets in the kitchen. Keep as little as possible in your black/grey/fresh water tanks.
LEVEL: This is EXTREMELY important yet few bother with it. Put a sprit level stick on just above and centered on your 3 trailer wheels on each side. Procedure: Take a sprit level and place against the outer wall and centered between the tires when it levels, draw a line about 2 in. do on both side of the trailer. Stick a sprit level (Wall Mart, 2 pack about $3 bucks) on the line.
When you load onto the bed of the truck you are going to need from 4-6 inches of clearance between the bottom edge of your truck rail bed and the 5th wheel. that is your co-wittness point. Level up the 5th wheel ones truck rail and insure or do your best to level up at the 2 rear wheel sets.
I would shoot for 6 in vertical clearance and adjust from there. To much down on the rear wheels were lead to premature tire wear, suspension wear, wheel bearing wear and brake wear increased PIN wt. Weight to the rear wheel set will do same only on the rear decreased pin weight.
DO your best to = the truck-wheel leveling and only compromise if you must.
Based on what the op stated the intended use of the truck is going to be, I think the gas option makes more sense economically. If it's a want and not a need, then by all means get the diesel.
In engineering we like the KISS method. If you have 20% less plastic hose Barb's under the hood, well that's less plastic to fail in 7,8,10 years. It's not just miles that wear a truck out. Time can as well.
Yea everyone wants to debate or rather ARGUE...M 16 vs AK47..again, there is no debate, one is an apple, the other an orange. On the flip side, small block Chevy vs small block Ford, nows there is a real debate...CHEVY!!!!
My engineers would often want to fall into debates on GUI vs Command Line interface (shows how far back I go). I would caution, there is no debate but we can discuss the merits of each.
