Sync 3.4 Update How To.
Old Jan 5, 2020 | 11:02 AM
  #196
leonmckee's Avatar
leonmckee
Originally Posted by Rocky Mountain F150
Can someone help me with the process of downgrading from 3.4 to 3.3?
PM sent
Leon McKee
Old Jan 5, 2020 | 11:11 AM
  #197
MrOneEyedBoh's Avatar
MrOneEyedBoh
Originally Posted by leonmckee
I've not done this myself, but here's what's been widely reported to work:
Sync 3.3 19025 is 4U5T-14381-AN
autoinstall.lst contains:
[SYNCGen3.0_ALL]
Item1 = 4U5T-14G381-AN.TAR.GZ
Open1 = SyncMyRide\4U5T-14G381-AN.TAR.GZ
Options = AutoInstall
Standard file structure.
Apps file goes into a directory called SyncMyRide
Autoinstall.lst file goes in the root directory.
Leon McKee
So essentially you're just going to make another USB 3 drive and plug it in? Or do you have to start over from USB 1 again? But replace USB 3 with the above?
Old Jan 5, 2020 | 11:14 AM
  #198
leonmckee's Avatar
leonmckee
Correct
The only potential gotcha is running out of memory on non-Nav systems from what I've observed. However, 3.3 is smaller, in file size, than 3.4 so that's a good thing.
Leon McKee
Old Jan 5, 2020 | 02:10 PM
  #199
MrOneEyedBoh
Thanks Leon.
Old Jan 5, 2020 | 04:23 PM
  #200
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
Fresh in from the cold driveway and I was able to grab some data (bored to death)!
USB Stick 2 - From Minute 1 to Minute 6 - Extracting & Updating Apps
Minute 6 to Minute 19 - Extracting Maps
Minute 19 to Minute 25 - Extracting Voice Navigation Pkg
Minute 25 to Minute 28 - Extracting Gracenote Pkg
Minute 28 - Installation Complete - You may remove your USB Device at this time.
USB Stick 3 - Takes about 10 to 15 minutes with absolutely NO NOTIFICATION on the screen until it is finished, so as the instructions say "Be Patient!!!" It does give you a dialogue box when it's done and tells you the software will take effect the next time you start your truck!
Hope this helps!
Old Jan 5, 2020 | 04:30 PM
  #201
h20camper's Avatar
h20camper
Hope this helps!
Good info. Since I don't have maps, I can deduct 13 minutes from my upgrade time.
Old Jan 5, 2020 | 06:13 PM
  #202
jimd1050's Avatar
jimd1050
Probably the "Voice Nav Pkg" time as well then, if you don't have maps!
Old Jan 5, 2020 | 06:20 PM
  #203
h20camper's Avatar
h20camper
I think I need the voice package.
VOICE = 5U5T-14G391-CB.tar.gz
Old Jan 9, 2020 | 04:14 PM
  #204
manowell's Avatar
manowell
A way to start the three stick process over? (I installed non-nav on a nav based system)
Title says it all, clicked on wrong link, downloaded NON NAV files and installed them on my NAV based unit (2017 KR).
It all worked, went quickly. TOO quickly. Now I have everything but nav sytem. Fault error, says "take it to your dealer".
I've built the correct three sticks now, but inserting USB 1 takes the ~10 mins of "Updating System" time then finishes, no prompt for USB 2. If I put in USB 2, the unit sees it and indexes it, but doesn't start the install.
Please tell me there's a way to fire off the upgrade/format/partition again?
Old Jan 9, 2020 | 04:34 PM
  #205
JHForman812's Avatar
JHForman812
you don’t need to run usb 1 again, you don’t have something on your USB stick properly. You should be able to put USB2 in and wait
Old Jan 9, 2020 | 04:35 PM
  #206
h20camper's Avatar
h20camper
Others might know better than me, but to use stick one again, you have to downgrade the v3.3 or earlier (via a stick two). You can then use stick one again and then go to the correct stick two. Make sense?
Old Jan 9, 2020 | 04:36 PM
  #207
JHForman812
stick 1 formats it so 3.2/3.3/3.4 can be installed, if he successfully did stick 1 then he only needs to start at 2.
Old Jan 9, 2020 | 04:54 PM
  #208
manowell's Avatar
manowell
I have a root directory with "SyncMyRide" folder with the sixteen files (downloaded individually from Tricon's link, zipping failed several times" and the reformat.lst file. (also from Tricon's posting)
Files:
Directory of M:\SyncMyRide
01/09/2020 02:56 PM 1,221,678,734 4U5T-14G421-CAB.tar.gz
01/09/2020 03:02 PM 954,135,073 4U5T-14G421-CBB.tar.gz
01/09/2020 03:02 PM 989,218,780 4U5T-14G421-CCB.tar.gz
01/09/2020 03:04 PM 1,212,632,947 4U5T-14G421-CDB.tar.gz
01/09/2020 03:08 PM 1,016,267,395 4U5T-14G421-CEB.tar.gz
01/09/2020 03:06 PM 998,883,559 4U5T-14G421-CFB.tar.gz
01/09/2020 03:13 PM 1,040,107,771 4U5T-14G421-CGB.tar.gz
01/09/2020 03:13 PM 996,018,234 4U5T-14G421-CHB.tar.gz
01/09/2020 03:11 PM 621,833,230 4U5T-14G421-CJB.tar.gz
01/09/2020 03:14 PM 1,341,414,725 4U5T-14G422-CAC.tar.gz
01/09/2020 03:17 PM 787,723,985 4U5T-14G422-CBC.tar.gz
01/09/2020 03:17 PM 563,493,831 4U5T-14G422-CCC.tar.gz
01/09/2020 03:18 PM 759,417,848 4U5T-14G423-CA.tar.gz
01/09/2020 03:21 PM 1,647 4U5T-14G424-CB.tar.gz
01/09/2020 03:23 PM 868,431,044 5U5T-14G381-CD.tar.gz
01/09/2020 03:22 PM 400,772,475 5U5T-14G391-CB.tar.gz
16 File(s) 13,772,031,278 bytes
reformat.lst has:
APPS = 5U5T-14G381-CD.tar.gz
VOICE_NAV = 4U5T-14G422-CAC.tar.gz
VOICE_NAV = 4U5T-14G422-CBC.tar.gz
VOICE_NAV = 4U5T-14G422-CCC.tar.gz
GRACENOTES = 4U5T-14G423-CA.tar.gz
MAP_LICENSE = 4U5T-14G424-CB.tar.gz
MAP = 4U5T-14G421-CAB.tar.gz
MAP = 4U5T-14G421-CBB.tar.gz
MAP = 4U5T-14G421-CCB.tar.gz
MAP = 4U5T-14G421-CDB.tar.gz
MAP = 4U5T-14G421-CEB.tar.gz
MAP = 4U5T-14G421-CFB.tar.gz
MAP = 4U5T-14G421-CGB.tar.gz
MAP = 4U5T-14G421-CHB.tar.gz
MAP = 4U5T-14G421-CJB.tar.gz
Old Jan 9, 2020 | 04:57 PM
  #209
JHForman812
Files:
reformat.lst has:
total size Of files on the USB will help me a little more.
it looks like they are all there it should be around 16GB. I don’t believe this makes any changes to the module, but if you look in the forscan forum maybe it shut nav off I’m not 100% sure. PM me and I’ll give you my number I’ll try to help. I’ve successfully went from 3.0 to 3.4 to 3.3 to 3.4 again 0 issues
Old Jan 9, 2020 | 05:13 PM
  #210
manowell's Avatar
manowell
16 File(s) 13,772,031,278 bytes is what the command said.
I just reformatted the USB stick, copying the files again now. used a different volume name so maybe it would look at it again.
