OK I am starting over and re down load the files for USB 2 from Tricon link above, now i am not sure i need the .LST file on my USB or on my USB inside the SyncMyRide folder with all the other files.
sorry for all the post I am usually very good at this stuff and im turning a 30 min job into an all nighter.
On your USB2 stick there should only be two things....the LST file and a folder called SyncMyRide with all the .tar.gz files inside. The LST file is not inside the Synch folder
Make sure the Sync folder has the same files as the USB2 file on Tricons upload
I had done the same thing an was using 1 USB stick to do the upgrade..
After it completed an I got threw looking around with it the she said was around 2am..
I paid for it the next morning tho as I needed to be up around 7ish,thank goodness I was able too pass that one
down the line..
If 3.4 is the latest updated software, why isn't Ford rolling it out to everyone?
I wouldn’t be surprised if Ford rolls out this 3.4 update next year to more vehicles so just be patient and wait for the real release for your vehicle.
Hence the reason not to install non approved updates from Ford that have only been approved for some / certain Ford vehicles.
No going back now.
Perhaps Ford will roll out this update next year for more vehicles.
I appreciate your admonishment (extremely helpful post too).
But formatting is formatting. If you format it one way, you can format it another. We're just talking about organizing digits here. All you need is the correct tool, not unlike the formatting tool included to enable the move to 3.4.
All is good now, lessons learned
1. Be sure to get a clean download of all files
2. After unzipping files check that complete file extension show tar.gz (In windows 10 you need to check box that says show file extensions)
3. Double check that all files you load on USB are correct files
Do it right and the update takes about 30 min, after you download files - unzip files - load files to USB
That last time I did the USB install method, I didn't start the engine. I put it in accessory mode and it did its thing. I did have a battery tender keeping the battery from running down.
damn you’re still having this issue? Go back to 3.3, you’ve already done the format 3.3 works. Next time I drive my truck I’ll take a picture and send it to you. To show you it’s working on 3.3
ill also admit you use more features than most of us. I use the gas price app on my phone.
