E350 Van...was a hot start issue
Old Jul 5, 2019 | 09:21 PM
  #31
bismic's Avatar
bismic
Can't rep you for it, but nice post Sean.
Old Jul 6, 2019 | 02:03 AM
  #32
Yahiko's Avatar
Yahiko
I think we are all in REP jail.
I wished I could access the PDFs I have for the transmission. The stupid computer won't boot right and I
found that you need XP Pro to make the PDFs that I post.
Old Jul 6, 2019 | 02:40 PM
  #33
Chris Wilson's Avatar
Chris Wilson
Originally Posted by Yahiko
With what you said about the shop hacking up the harness I think I would start by checking for any broken or mis-spliced wires.
Also there is a harness that runs down the back of the trans. and that might be worth reaching up from the ground to feel for and
also check where the harness enters on the transmission right side. It passes through the case and into the valve body. The
easy one to check (well maybe not in the E-series) is the plug on the PCM. Make sure all three are fully plugged into the connectors.
That harness is easily viewed...the doghouse makes everything on the rear end of the motor available to me...the front is where it's a PIA. They cut off a couple harnesses that run along the engine compartment top...also looks like they changed the bottom plug ends on the ficm..and the top plug set is ziptied to the ficm...now that was all done at the shops way in the begining 8 years ago...
Old Jul 6, 2019 | 02:44 PM
  #34
Chris Wilson
I was going to go down today but I decided to wait until tomorrow. A new icp plug and trs will be here
Old Jul 6, 2019 | 04:14 PM
  #35
bismic's Avatar
bismic
Hopefully the sensor resolves it. It could still be in the harness internal to the transmission or the external one to the PCM.
Old Jul 6, 2019 | 04:30 PM
  #36
Yahiko's Avatar
Yahiko
If you still have issues I would go over any splices you can reach and check them.
Old Jul 7, 2019 | 06:35 PM
  #37
Chris Wilson
The icp was unplugged when I scanned it. I plugged it in and same results. So I changed the plug end. Same deal..I cant find the neutral safety switch/ trans range sensor and whatever else names there are for it. I guess it's in the trans pan?
Now...what is the 4 wire plug behind the alternator? When I rehooked everything up origibally. I keep connecting it but I just dont feel a good connection on it and the red lock thing dont seem to work worth a crap
Old Jul 7, 2019 | 06:39 PM
  #38
Visurveyor's Avatar
Visurveyor
Glow plug harness.
Old Jul 7, 2019 | 06:50 PM
  #39
Chris Wilson
Well that's not the problem then....
So wtf kind of over engineering puts that sensor inside the trans pan...jesus!
Old Jul 7, 2019 | 06:57 PM
  #40
Visurveyor's Avatar
Visurveyor
Ford.
They are not hard to replace. When you do a full filter change they are right there, plug and play as they say. But when they go you have to do it.
Sucks, but truck has been sitting 8 years.
Old Jul 7, 2019 | 07:17 PM
  #41
Chris Wilson
Well...what's reccomend as far as fluid then...
Old Jul 7, 2019 | 07:23 PM
  #42
IHateCommieCars's Avatar
IHateCommieCars
Originally Posted by Chris Wilson
I donno about that...or maybe the fact this is a van and space is such a f'n premium lol
Definitely. The vans are a beech. If you just accept that you're gonna have to take everything out from under the hood, and get that over with. It's easier afterwards.
Old Jul 7, 2019 | 07:26 PM
  #43
Visurveyor's Avatar
Visurveyor
Motorcraft Mercon SP or LV. A lot of squabbling over that but either one will do.
Old Jul 7, 2019 | 07:45 PM
  #44
bismic's Avatar
bismic
I think that generally the Valvoline MaxLife has also become acceptable!
Old Jul 7, 2019 | 08:16 PM
  #45
Chris Wilson
As far as mc or shelf filter?
