E350 Van...was a hot start issue
Old Oct 9, 2019 | 04:58 PM
  #136
Chris Wilson's Avatar
Chris Wilson
Well guys...its running!!... I do have an oil leak at the turbo...but it ran!
Old Oct 9, 2019 | 05:08 PM
  #137
m-chan68's Avatar
m-chan68
What was the fix?
Old Oct 9, 2019 | 05:34 PM
  #138
Visurveyor's Avatar
Visurveyor
Curious on the fix to.
on the oil leak, oil return tube. probably o rings are bad.
Old Oct 9, 2019 | 05:54 PM
  #139
Chris Wilson
I had to get home so I couldn't get into the leak too much. It appears to be at the top of the turbo. I wasnt really keen on how it seated at the feed line.
This rotomaster turbo has been a weird fitment. I should have returned it but I wanted to get stuff done. So it has something to do with the bolts(old and new ones wouldn't get snug so I got shorter ones) or how its sitting on top
Old Oct 9, 2019 | 05:55 PM
  #140
Chris Wilson
Originally Posted by m-chan68
What was the fix?
Perseverance.....and a new hpop
Old Oct 9, 2019 | 06:08 PM
  #141
Visurveyor's Avatar
Visurveyor
Did ya put the gasket or chect if it was there when you replaced the bolts on feed line.
Old Oct 9, 2019 | 06:09 PM
  #142
Yahiko's Avatar
Yahiko
Di you used a new gasket for the top oil feed?
Old Oct 9, 2019 | 06:14 PM
  #143
Chris Wilson
Yeah i bought a ford turbo seal kit now knowing the new one came with it. used the orings on the drain and the gasket on top. Didnt change the oring on the tube at the cooler.
Old Oct 9, 2019 | 06:29 PM
  #144
Visurveyor's Avatar
Visurveyor
If it's at the top of turbo. It's the gasket. If it's at the oil cooler housing it would be bad alignment or o ring.
Old Oct 9, 2019 | 06:32 PM
  #145
Visurveyor's Avatar
Visurveyor
Ow and your bolts could still be to long. Maybe Bismic will se this post.
He would more than likely be able to tell ya the exact diameter of bolts. Yahiko to..
Old Oct 9, 2019 | 06:34 PM
  #146
Yahiko's Avatar
Yahiko
You did not bring up the nasty one.
Cracked port that the oil supply line goes into. But that one is not at the top.
Could be some old gasket left on the oil feed at the turbo.
Old Oct 9, 2019 | 07:01 PM
  #147
Chris Wilson
Hopefully it's as easy as the bolts on top. But I'll see tomorrow. But with my flash light I couldn't see any oil up at the cooler as I never even took it off there. I just left it in. I do have the flex line which on a van its probably a necessity. The oil leak just appeared to be from the top supply down to the valley and down the sides
Old Oct 14, 2019 | 05:12 PM
  #148
Chris Wilson
Well after going to shorter bolts I dont have a leak. Started again as well and here's some torque #s let me know
Old Oct 14, 2019 | 05:18 PM
  #149
Visurveyor's Avatar
Visurveyor
Post readings at operating temps and rpms. Mostly looks good.
Old Oct 14, 2019 | 05:20 PM
  #150
Chris Wilson
Here's my bolt h@ll ....left is oem size and kit size...stainless was my puddle and far right is what it ended up being
