Passing the torch
Old Aug 17, 2019 | 03:31 PM
  #91
jjriley97's Avatar
jjriley97
Originally Posted by 78ShortBed-
K. Couldn't remember if it was a 6 or V-8.
So original filter is in the pump.
Yeah there wasn't one. I added one before the pump and also got the pump changed. Not only does it go down the road better, but the idle smoothed out. I'm calling it fixed until the next thing.
Old Aug 17, 2019 | 09:25 PM
  #92
BarnieTrk's Avatar
BarnieTrk
The OEM fuel pump has a filter element inside the lower canister threaded onto the bottom of the pump.
JJ, what type/size of a filter did you install upstream of the pump?
BarnieTrk
Old Aug 18, 2019 | 02:32 PM
  #93
jjriley97's Avatar
jjriley97
The fuel pump that was on there for 78 (motor was donated from a 78) did not have a canister, though the one you posted looks like it would work. It is a sealed unit.
The filter I used is just a basic inline filter. I've got to reroute some fuel lines at some point so I will probably put a glass one on there. It is running so much better now after the pump replacement.
Old Aug 18, 2019 | 08:05 PM
  #94
BarnieTrk's Avatar
BarnieTrk
JJ,
Opps, I forgot you have a transplanted 300 6cylinder engine in your truck.... I was thinking it was a 352 v8.
I don't know if the pumps would interchange or not.....
What condition was the insides of the fuel tank? Was it rusty or no? Do you feel you got it pretty well cleaned out?
BarnieTrk
Old Aug 18, 2019 | 08:57 PM
  #95
jjriley97's Avatar
jjriley97
It was brand new when dad got it and it is flawless. The fuel system is as close to new as I'll get.
Jim
Old Aug 20, 2019 | 07:09 PM
  #96
BarnieTrk's Avatar
BarnieTrk
Originally Posted by jjriley97
It was brand new when dad got it and it is flawless. The fuel system is as close to new as I'll get. - Jim
SWEET! BarnieTrk
Old Aug 28, 2019 | 08:02 PM
  #97
78ShortBed-'s Avatar
78ShortBed-
Email sent.
Old Aug 30, 2019 | 08:50 AM
  #98
jjriley97's Avatar
jjriley97
In my quest to gather parts for this truck and get it back to where it came from, mostly anyway, I had decided to go with steelies and beauty rings/caps. Not a choice I ever, ever, ever thought I would make. It just fits this though and I like them much better than the early 90's wheels that dad put on it. I found these local and will be picking them up next weekend on my way to mom's house as the guy is right on the way. Best part is $50 is getting the deal done. They will be red when all is said and done.
Old Aug 30, 2019 | 10:19 AM
  #99
78ShortBed-
That should sharpen the old truck up. Those trims rings reminded me, I have a set hanging on the wall. Lol
Black or red strip...I'll have to look.
Old Aug 30, 2019 | 03:46 PM
  #100
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
These trim (beauty) rings were originally installed on 1940/48 Ford/Mercury Passenger Cars. Both 15" and 16" were available.
Old Aug 31, 2019 | 12:06 AM
  #101
jjriley97's Avatar
jjriley97
Thanks for the info. I was wondering. The guy I'm getting them from pulled them off of his 71 f100.
Old Aug 31, 2019 | 06:57 AM
  #102
BarnieTrk's Avatar
BarnieTrk
JJ,
I'll bet those wheels/rings/caps will look SWEET on your ol' Slick!
Will you use the same tires you have or buy new tires?
Is it safe to say the current wheels are likely off the same '78 van that donated it's 300" engine?
They look to be in decent shape; you should be able to flip them for some cash towards offsetting other expenses......
BarnieTrk
Old Aug 31, 2019 | 10:51 AM
  #103
jjriley97's Avatar
jjriley97
Thank you. The family and I think so too.
The current wheels are easily to mid 90's.
Unfortunately the tires on it are 235 and the new rims are 15x5. I'll end up going with a 215 probably. Once I put it up for the winter, I'll sell off the 235's to pay for the new ones.
Old Sep 2, 2019 | 08:02 AM
  #104
BarnieTrk's Avatar
BarnieTrk
Sounds like a plan!
BarnieTrk
Old Sep 16, 2019 | 09:40 AM
  #105
jjriley97's Avatar
jjriley97
The power steering pump is now rebuilt and working great. This took care of the biggest leak on the truck and got rid of the noise the pump was making. On to the next thing.
