Roll Call - - -
Old Mar 7, 2005 | 06:45 PM
  #121
50 F-1's Avatar
50 F-1
Hello Carlene. I'm new to this site as of today. My name is Charlie, I have a 50 PU and it is a project. Found this site and like what I read, and look forward to help in my project and my provide help with what I know.
Old Mar 16, 2005 | 03:33 PM
  #122
thatmike's Avatar
thatmike
Hi Everyone!
I'm new here so bear with me.
Looking for hints on modifying my (new to me) 1957 F100 truck.
It has a 272 Cu in V8 with a Fordomatic Auto trans too.
It has those crawling gears and I really would like to swap out Highway gears most likely 280-300 ratio in the 9" rear.
I hear Ford 9" rear ends are the easiest to work on, but perhapos someon can assist me with information on used or remanufactured spline and other gears nec.
This truck is really nice and solid and everything else works just fine. So if you could assist me I would appreciate it very much.
Thanks and have a Great Day!
Mike Turocy 904 229-9886
Old Mar 16, 2005 | 04:05 PM
  #123
uba40's Avatar
uba40
Mike,
I can't speak for anyone but myself. I would look for a set that is already done. The "pumpkin" unit itself takes but less than an hour to change. Find a complete "pumpkin" unit which has the ratio you desire, and swap them out.
I personally would not go through the effort of buying a new gear set, and having them installed in your 3rd member. This rear end unit is so beefy, and lasts so long, you could probably get the set you want from a wrecking yard, and be money and time ahead of the game.
My opinion.......
uba40
Old Mar 16, 2005 | 04:30 PM
  #124
KennethKvittum's Avatar
KennethKvittum
Kenneth Kvittum from the great state of Oklahoma, project 47 1/2t out with the old in with the new , currently looking to drop the flathead and install 302-C4
Have other Ford Projects
Old Mar 26, 2005 | 09:46 PM
  #125
Hammockjames's Avatar
Hammockjames
Howdy, I'm James from Arizona. My oldest friend is a 1941 Ford 1 1/2 ton pickup. I've been restoring him bit by bit since I found him In crystola Colorado back in 1990.
Old Apr 11, 2005 | 12:44 AM
  #126
mrbones's Avatar
mrbones
mrbones-1943 Navy cargo truck
Southern California here. I have a restored 1943 ford navy cargo truck. It's a great truck. I am on this site to find out as much as I can about this truck because I know absolutely nothing about it. So any information that anyone can supply will be greatly appreciated.
Old Apr 12, 2005 | 07:38 PM
  #127
popaa38's Avatar
popaa38
popaa38
Aloha! I'm Malcolm Makua from Hilo Hawaii. I have a 38 1/2 truck that picked up in Washington, NC in 1997. I put the cab and box on a 39 frame and instead of the flathead, I adapted a 350 chevy motor to the 3 speed. In Aug 1999, I drove from Hatteras, NC to Los Angelos, CA. (mostly on I-40) and then shipped it to Hilo hawaii. Here in Hilo, it seems everyone knows me as the guy that drives the old truck, with the surfboard on the rack. Again Aloha to y'all.
Old Apr 12, 2005 | 11:08 PM
  #128
Suljer's Avatar
Suljer
Completely customized 1949 Ford F-1, 1/2 Ton Pickup. All orginal except 12V system, 302 V8 engine and 3 speed automatic transmission.
Currently looking for driver and passenger doors.
Old Apr 15, 2005 | 12:22 PM
  #129
TUFF TIN's Avatar
TUFF TIN
New Old Guy
Geeeze! Thought that I had given my intro. Anyhow......... been into cars since 1949 and currently drive a 1951 Ford Vicky hardtop and have a 40 Ford Pickup; 56 Ford Pickup and 53 Ford Tudor in the shop as projects. The 56 F-100 is black with wide whites, white upholstery and white tonneau cover.
If I can help anyine, drop me a note at tufftin@crestview cable.com.
Thanks
Mike
Old May 10, 2005 | 10:12 PM
  #130
howdy71475's Avatar
howdy71475
Hello I'm howdy71475 (real name Howdy) I am an ametuer restorer of old iron. I currently am working on a 47 tonner, a 47 comm with duals and a stake bed, a 61 short and wide unibody, a 51 IHC L120, and many more projects waiting te get started. Have been doing this kind of thing for quite a while and am always happy to help.
Old May 29, 2005 | 11:19 PM
  #131
WQ59B's Avatar
WQ59B
Central New Jersey reporting in.
In '03 I bought my 'dream truck', a '40 Ford COE cab/chassis, 134" wheelbase, 2-spd (5.83/8.11) rear, later ('46-47) grille and '46-48 59AB flathead. Ex- Humble Oil tanker truck (tank & equipment long gone). Ran fine in '03, since then I am most of the way thru refurbishing the fuel, ignititon, cooling & brake systems. Body is all there with limited rot & some banged-up fenders. Intend to leave the chassis bare and the cosmetics alone but make it roadable- looking for limited road time later this summer.
Old May 31, 2005 | 08:22 PM
  #132
47Panelman's Avatar
47Panelman
Have a 47 Ford Panel, 1 1/2 ton I think. Tons of springs!
We're rebuilding it, nixed the front axle opting for a Mustang II front end kit. That lowered it real nice. Pulled 5 Leafs and dropped the back-end about 2-3 ".
Has a 302 basically stock but fresh, haven't even started it yet.
Primary reason I'm here is I found the site looking for aftermarket turn signals for the front.
Old Jun 3, 2005 | 11:56 PM
  #133
40_4x4_trk's Avatar
40_4x4_trk
Hi all
Hi Carlene and everyone else,
I a new member and I am in the design and plannig stage of a '40 crew cab 4x4. I would appreciate any an all help and advice on this project. I also own a 1991 Aerostar. I have had and restored or rodded several other fords 2-'70 mustangs, '80 mustang, 2-'35 's and a '36 coupe.
Old Jul 13, 2005 | 08:09 AM
  #134
Boatusrob's Avatar
Boatusrob
Hello Carlene,
This is Robert from Houton, Texas and I am building a 1941 1/2 ton pick up, this is my first Ford to do, but I am having a blast. I don't know all that much about these old Fords, that is why I joined this group, thought there would be a great deal of info here, I was right.
Old Jul 13, 2005 | 12:54 PM
  #135
bubba22349's Avatar
bubba22349
Hi Robert,
Welcome, my name is Robert and I have a 41 truck too. Mine is a Sedan Delivery. They do share the same chassis though not much else. Good Luck with your pickup.
