Roll Call - - -
Old Jan 2, 2004 | 11:16 AM
  #31
alittle40's Avatar
alittle40
Hi Carlene and Steve,
I'm the AL in alittle40, and I do have a '40 Ford Pickup that is the process of rebuilding. I picked this one up in about a couple hundred boxes and have been putting it together for the last few years. My New Year's Resolution for 2004 is to put this truck together and have it painted and driving this year. Will update picture gallery as work progresses.
Carlene, your doing a great job on this site as usual.
Old Jan 5, 2004 | 04:29 PM
  #32
aldauria's Avatar
aldauria
Originally posted by gbhobbyshop
Hi I have a 40 pickup I am putting on an 5.0 allwheel drive explorer chassis,also have a 46 that I will be parting out.I have built rods and musclecars forever,this is my first truck.Iam missing a lot of parts!Any body got any extras!..
Thanks........... Gary
Hi,
If you're parting the 1946 PU I may be interested in one special item. I do have a 1947 1/2 Ton at the final stage of restoration here in S. Paulo, Brazil.
I look for the sheet metal part that surrounds both the steering column and pedals (clutch & brake).
Thanks
Antonio
Old Jan 5, 2004 | 10:14 PM
  #33
Reg Wal's Avatar
Reg Wal
Wish you were in the USA, there are parts off the 46 I could use.
Old Jan 6, 2004 | 01:32 AM
  #34
46yblock's Avatar
46yblock
Antonio, if you need the sheet metal floor seals, and don't have any luck, I have two sets you can have reasonably. Probably should start a new thread on this if you are interested.
Old Jan 6, 2004 | 04:42 AM
  #35
aldauria's Avatar
aldauria
Thanks for your reply. If you have the right parts I am interested on them. Just let me know how to proceed.
Antonio
Old Jan 6, 2004 | 03:41 PM
  #36
41Clay's Avatar
41Clay
It's been a long time since I took mine off, but arent' those just flat peices of metal? If so it would probribly be very easy to make or have made locally with the demensions at hand.
Old Jan 6, 2004 | 04:11 PM
  #37
46yblock's Avatar
46yblock
I wouldn't say it is easy, but I did make my own. Used a different steering column setup so the originals wouldn't fit. Cut the seal out of sheet aluminum. Required about a day of on and off work.
Without a pattern, a person should rough one out of cardboard and then transfer to the metal. I used a saber saw combined with a hole saw, and finished with rotary grinder.
Mike
Old Jan 7, 2004 | 04:02 PM
  #38
41Clay's Avatar
41Clay
I was thinking of a friend of mine who owns a shop that has a plasma cutter that can cut patterns from drawings. I would take the deminsions of mine if they were at hand, but they are in storage somewhere far from where I am.
Old Jan 8, 2004 | 08:49 AM
  #39
46fordtruck's Avatar
46fordtruck
Who was in the USA? I'm currently in Phoenix, AZ...but I'll be moving back to where my trucks are in Orange County, Ca in the next month, month and a half. I will be tearing down a complete '46 that I used for the cab. I have most a whole truck that will be part out. Let me know if you need anything by emailing me directly. It would be about 2 months before I get back and am able to tear the truck down.
Old Jan 9, 2004 | 09:11 PM
  #40
40 PICKUP MAN's Avatar
40 PICKUP MAN
HI, I AM JOHN, FROM SOUTH FLORIDA AND HAVE 1 AND A HALF 1940 PICKUPS, AND JUST STARTING SO AS TO HAVE ONE GOOD DRIVER. NEED RUNNING BOARDS, ANY HELP?
Old Jan 9, 2004 | 09:14 PM
  #41
Carlene's Avatar
Carlene
Admom
Hey John - welcome from another S. Floridian.
Sorry I can't help you out on the running boards but maybe one of the Northern guys has a decent pair. Good luck on your search.
Old Jan 10, 2004 | 06:44 PM
  #42
40 PICKUP MAN
Thank you for the welcome.
Old Jan 31, 2004 | 08:39 PM
  #43
Fire438's Avatar
Fire438
I am working on a 1938 one ton (as far as I know) . It runs and needs alot of body work. It used to be a service truck on Interstate 70 and was used everyday until the early 80's. My grandfather drove it the 80 miles home after he bought it at 70 mph. It has a 85 hp flathead. I look forward to getting help and maybee even helping you in time.
Old Feb 18, 2004 | 02:47 PM
  #44
bubba22349's Avatar
bubba22349
Hi my name is Bob (bubba22349) been into Fords most of my life bought first one at 14. I have one major rebuild project a 1941 Ford Sedan Delivery. Also have a 1956 F-350 Transporter, a 1958 Ranchero, and 1994 F-150. Bob
Old Feb 24, 2004 | 05:59 PM
  #45
Mountain's Avatar
Mountain
Hey ya'll. I'm Mountain and live in North Georgia. I'm working on a 1947 that was pretty much just a shell when I started. I had a '46 mounted on a '69 Bronco chasis back in the early to mid '80's and am in the process of replacing her utilizing the original frame, cab, front clip, and bed w/300/6, granny 4spd, and 4x4. Need original windshield/defroster frame, centerstrip (inside and out), headlight retaining rings, headlight trim rings, front turn signals, both windshield halves, both side glasses, and grill strips. She won't be a show truck, so the rough pieces you discarded might work for me. Good Luck on your projects.
