390 build
Old Jan 30, 2018 | 10:15 AM
  #31
smoky_diesel's Avatar
smoky_diesel
What cylinder heads are you planning on using?
Old Jan 30, 2018 | 10:50 AM
  #32
70FE250's Avatar
70FE250
The edelbrock performers
Old Jan 31, 2018 | 08:13 PM
  #33
70FE250's Avatar
70FE250
Don’t know why I didn’t inspect it right away, but upon further inspection of the rods they are the C7AE-B rods, so I get to get away with a little more sturdiness on the rotating assembly side. Block matched with that of a 428 CJ which made me happy for a second, then I remembered ford block casting numbers don’t matter for these year engines and that my bore was the stock 4.05. So that faded quick. Friday is coming up and I’ll be picking up my good as new block!
Old Feb 2, 2018 | 05:47 PM
  #34
JEFFFAFA's Avatar
JEFFFAFA
You'll have to have valve springs that can handle that 530 lift.
Old Feb 3, 2018 | 11:50 AM
  #35
70FE250's Avatar
70FE250
I will be getting edelbrock heads with better springs so I should be fine I believe.
Picked up my block from the machine shop and oh my does it look good!
Old Feb 3, 2018 | 09:04 PM
  #36
fe390pc's Avatar
fe390pc
That block looks good, quality work.
Now spend some time cleaning the casting flash so you don't have any sharp edges to cause cracks. Do this inside and out.
Old Feb 4, 2018 | 12:59 AM
  #37
70FE250's Avatar
70FE250
At the end of my second day of working on the engine, got as far as I could with installing the crank, cam and timing gear and whatever miscellaneous parts until my rods are done at the shop
Old Feb 4, 2018 | 10:55 AM
  #38
MIKES 68 F100's Avatar
MIKES 68 F100
eddy heads have springs that can handle .600
Old Feb 4, 2018 | 12:11 PM
  #39
70FE250's Avatar
70FE250
I had kinda figured that, I just wanted to make sure rocket wise with end stands I wouldn’t have an issue with running that lift and spring combo
Old Feb 5, 2018 | 04:28 PM
  #40
JEFFFAFA's Avatar
JEFFFAFA
The timing alignment mark on the cam gear is at about the 2:00 position in this pic. You did mount the timing chain and gears with the cam gear mark at 6:00 and the crank gear's mark at 12:00, correct?
Old Feb 5, 2018 | 05:33 PM
  #41
70FE250's Avatar
70FE250
Yes it was installed properly, I had just spun the rotating assembly around a few times to test everything
Old Feb 6, 2018 | 12:31 PM
  #42
70FE250's Avatar
70FE250
Could anyone tell me what kind of power loss id see from the T18 and Dana 60 rear?
Old Feb 7, 2018 | 08:49 PM
  #43
fe390pc's Avatar
fe390pc
Well the T18 and Dana 60 have a combined parasitic loss of about 15% depending on who you ask. So if your flywheel horsepower is 400 your rear wheel horsepower will be around 340. Math is a wonderful and useful tool!
Old Feb 13, 2018 | 07:52 PM
  #44
70FE250's Avatar
70FE250
Got another question for y’all. I found some reconditioned 390 heads with CJ sized valves for sale for 600 dollars. Is this worth it to you guys? Only issue is I’d have to wait about 3 weeks to get it.
Old Feb 13, 2018 | 08:45 PM
  #45
Frosty67's Avatar
Frosty67
Are the 390/CJ valve heads off ebay? I just ordered a set (took 3 weeks) they were nicely finished. I had my local shop check them for spec and they were good to go.
