3rd Brake Lamp Camera
Old Mar 21, 2018 | 01:11 PM
  #61
Sarge261's Avatar
Sarge261
I ordered a harness using the vin I have and parts should be here in 3 days so fingers crossed.
Also the FU2Z-14S411-DA already superseded to the FU2Z-14S411-DB, which I already have, back to the drawing board.
Sarge
Old Mar 21, 2018 | 05:46 PM
  #62
1956Fatfenders's Avatar
1956Fatfenders
Originally Posted by Sarge261
That is the CHMSL harness, the camera is integrated into that harness if the truck is equipped. The interesting thing to see is what does the connector at the C-pillar look like and does it already have the extra pins in it for the camera. If id does not then the body harness is not the same for all Lariat-up trim levels. .
Sarge
OK Sarge261, ask and you will receive. We're determined to make this work. I yanked the c-pillar cover once again, pulled the headliner down just enough to see, and can report the following:
My current inter-connecting CHMSL harness, has part # HC3T-14A411-EB on a tag. Useless (so far), as that number doesn't come up...
My cab's C-pillar harness feeding the CHMSL inter-connecting harness, has 6 wires;
2 - 18ga - Black, Blue/Red (I'm guessing on wire gauge for all)
4 - 22ga - Purple, Black/Yellow, Black, White
My CHMSL Harness has the following;
3 - 22ga - Purple, White, Black (Not sure of order, but...Cargo Lite 12V+, 3rd Brake 12V+, and Ground)
This means there are 3 remaining wires in my cab C-pillar harness NOT feeding the CHMSL harness;
1 - 22ga - Black/Yellow
These MUST be for the camera...
I'm looking at trying to make this work two different ways:
  1. Find the proper CHMSL/Camera cable. This would be easiest..dah!
  2. Add the missing wires to my existing CHMSL cable, and replace the upper connector where it meets the CHMSL/Camera pigtail (using Molex 19419-0001, shown below)
#2 would require sourcing the CORRECT connector, which I've spent hours on already between the Ford Workshop Manual, Molex website, Mouser, and Newark websites.
#2 would also requiring purchasing the correct crimping tool(s), pins, etc, which I'm in the process of determining if its financially worth it
I've determined the connector that Sarge261 showed coming off his CHMSL/Camera pigtail, as being a Molex Receptacle 19418-0001, found at Newark -
Newark.com
The male version is Molex Connector 19419-001, which would be required to retrofit my existing cable;
Obviously, there are no pins inserted yet.
Below is the connector from the inter-connection cable between the C-pillar harness, and the pigtail on the CHMSL/Camera. Now, to do some more digging to see what this connector is, then decide if I want to make and entire new cable. Heck if this all works, I could probably sell the cables if they can't be sourced!
As usual, there are NO markings on this connector.
And we trudge on..............................
Old Mar 21, 2018 | 05:55 PM
  #63
1956Fatfenders
Sarge
That's really odd since my Workshop manual list both as separate pigtails...???
And here's a little Super Duty trivia - Our trucks use over 1000 different connectors, per the Workshop Manual. Takes a while to locate the correct one...
Old Mar 21, 2018 | 06:58 PM
  #64
1956Fatfenders
Alrighty. So, we can see by Sarge261's picture, and my picture, what the two connectors LOOK like.
Looking at this drawing, we can now identify the two connectors in question. C9125, and C3047, which reside at opposite ends on the harness feeding the CHMSL w/camera.
From the connector diagrams, C9125 (which I posted earlier before i started to figure out the Workshop Manual):
...and C3047. IF making our own cable, we'd use the "FEMALE" illustration.
Old Mar 22, 2018 | 07:33 AM
  #65
Sarge261's Avatar
Sarge261
In theory 14A411 should be the complete harness, I do know for a fact that WPT-1415 (Pigtail) is the correct pig tail for the CHMSL end of the harness. If I get the wrong harness and the correct number of pins is in it I'm determined to make it work, even if I have to figure out what I need to buy to connect to the truck side.
When I gave my parts guy the pig tail part numbers from the diagram he told me it was superseded. It'll be a few days before I can post back but that will give me time to lower my head liner and get my C-pillar molding off.
Any tips or tricks I should know about to do the headliner Fatfender? I do appreciate your help spurring this project along, Ive got quite a few bucks wrapped up in it now but I'm determined to make it work now!
Sarge
Old Mar 22, 2018 | 10:59 AM
  #66
1956Fatfenders
Sarge
All I did was release the C-pillar and reach up to pull the headliner down just enough at the back corner to see up under it. To go farther, likely need to remove the dome light. Here are instructions someone else posted for headliner removal. Skip to to the appropriate step since you're not removing it entirely.
File Type: pdf
Old Mar 22, 2018 | 02:06 PM
  #67
Greg McMahon's Avatar
Greg McMahon
Here is what the back of the Lamp and Camera Looks like and a good shot of the harness end.
It the part number of this lamp & camera HC3Z*13A613*D?
Old Mar 23, 2018 | 07:32 AM
  #68
Sarge261's Avatar
Sarge261
Yes sir that is the part number I bought
Old Mar 23, 2018 | 07:55 AM
  #69
Sarge261's Avatar
Sarge261
Thanks,
I don't need to remove it entirely but I need more room so I can run my antenna.
Sarge
Old Mar 23, 2018 | 11:42 AM
  #70
Greg McMahon
Ok so then HC3Z*14A411*D is the correct harness. My dealer was very persistant that we had the correct harness, but he agreed we were missing the correct pigtail. So, we order another harness assembly and it had the additional pigtail on it. The original harness must of been miss packaged.
Old Mar 23, 2018 | 01:17 PM
  #71
Sarge261's Avatar
Sarge261
Can you post the pictures when you get the harness?
Old Mar 23, 2018 | 01:41 PM
  #72
1956Fatfenders
Yes. We need this ^^^^^^
Was considering just making a cable as the connectors are cheap. Problem is the special Molex crimper 63811-4800, is nearly $350.
Old Mar 23, 2018 | 02:11 PM
  #73
Sarge261's Avatar
Sarge261
I should have my harness Monday or Tuesday....part 2 to this project is going to be figuring out if the wiring for the switch is behind the trim bezel near the radio and then seeing if it can actually be viewed on the screen....we're oh so close!
Sarge
Old Mar 23, 2018 | 03:45 PM
  #74
JeepPuller's Avatar
JeepPuller
Sarge
I'm watching this closely! Kudos to you guys for pioneering this effort!!
Old Mar 23, 2018 | 04:16 PM
  #75
Greg McMahon
Yes, not a problem. Was planning on posting them as soon as I got home. The middle of the five connectors is the one for the CHMSL...
