3rd Brake Lamp Camera
Old Jan 19, 2018 | 11:28 AM
fitz2012's Avatar
fitz2012
Has anyone with a Lariat ultimate pulled the 3rd brake light yet to see if the wiring for the camera is already there?
Old Jan 19, 2018 | 11:32 AM
jimmyv13's Avatar
jimmyv13
That's a great idea...if I remember, I'll check it out this weekend.
Old Jan 19, 2018 | 02:48 PM
fitz2012's Avatar
fitz2012
I just looked, only a black, orange and white wired connector plugged directly into the 3rd brake light.
Old Jan 21, 2018 | 03:32 AM
Overslope's Avatar
Overslope
Gonna keep an eye on this thread. I'd like to do this as well.
Old Jan 21, 2018 | 01:15 PM
1956Fatfenders's Avatar
1956Fatfenders
I'm still thinking this is possible. Thanks to @UpInSm0kE for posting this cab wiring routing diagram on the "Upfitter thread. The red arrow points to the connector in the lower photo.
I pulled the left C-Pillar cover to see what the harness feeding the 3rd Brake Light looks like. What I see, is many wires feeding that connector, and only 3 or 4 coming out. I think adding the camera just MIGHT be possible.
If I can source the 3rd brake light camera and associated harness at a decent price, I might just take a chance that this will work. How to activate the camera might be the question, unless its recognized when it is plugged in???
Old Jan 22, 2018 | 10:25 AM
Sarge261's Avatar
Sarge261
Maybe someone can dig up part numbers for the lamp and harness if its needed. I'm willing to try. The only thing beyond that we may need is the toggle switch that the tow bundle trucks get for the dash to scroll through the cameras.
Sarge
Old Jan 22, 2018 | 10:52 AM
1956Fatfenders
Sarge
I was going to say the same thing. Hopefully, there's someone on this forum that works in Parts, that could get numbers and good pricing.
Old Jan 24, 2018 | 11:34 AM
1956Fatfenders
I need someone (in parts???) to confirm this information:
It would appear the harness part number was: FU2Z-14A411-DB, which has superseded to: FU2Z-14S411-DB. In the Workshop Manual, it is identified as: C9125.
Best I've been able to determine, the CHMSL Camera is: HC3Z-19G490-A After further searching, this part number is for the CAMERA ONLY. I'll keep looking.
I came up with the harness number based on the 2017 Super Duty Workshop Manual. The CHMSL Camera was found using a manual search. I searched for a Platinum model that has the camera, and used it's VIN to search for the part.
Again, I CANNOT confirm these are correct numbers.
Old Jan 24, 2018 | 12:27 PM
Ram2Ford's Avatar
Ram2Ford
Subscribed. Would love to know if this is an affordable solution.
Old Feb 28, 2018 | 11:04 AM
Sarge261's Avatar
Sarge261
Ok here's an update:
HC3Z-19G490-D (Complete Lamp Assembly w/Camera)
I should have the parts late this week or early next week, I'm not sure when I will get them installed but Ill do my best to get to work on it right away.
The harness is fairly cheap at right about 20 bucks, the lamp not so much, my dealer charged me about 200 bucks for that.
Fingers crossed, that its plug and play but I'm not sure it will be. I'm hoping someone that knows forscan well may be able to help me because I'm not that computer savvy.
Sarge
Old Feb 28, 2018 | 01:26 PM
UpInSm0kE's Avatar
UpInSm0kE
Sarge
Sub'd Good Luck Sarge!
Old Feb 28, 2018 | 01:37 PM
honda250xtitan's Avatar
honda250xtitan
Sarge
Awesome, can't wait to see if it works out. I'm short, i can't see the gooseneck ball at all from the cab lol.
Old Feb 28, 2018 | 05:47 PM
  #28
1956Fatfenders
I don't believe your getting a complete assembly. I Googled your part number (which is similar to the one I had), and they all come up with just a camera (I'd assume) for $75 - $80. Changing the suffix letter, bring up different cameras. I THINK the CHMSL + Camera should be closer to a couple hundred.
This description from FordPartsGiant.com doesn't even mention the High Mount Stop (I did not highlight or bold any of the below, its all cut-n-paste, so no emphasis intended):
Ford Part No.: HC3Z-19G490-D
CAMERA - PARKING
Your Price: $76.24Retail Price: $109.53You Save: $33.29Qty: ADD TO CART
This part fits the following vehicle options:
  • Fit Note: Rear Video Camera And Prep Kit
  • Production Date: 07/2016-
I looked up a used 2017 SD on Cars.com that included the camera in the CHMSL, used that VIN on TASCA Parts, and it came up with the 13A613.
I think the middle digits need to be 13A613. Like this - https://www.tascaparts.com/oem-parts...ed-hc3z13a613d
Old Feb 28, 2018 | 09:40 PM
  #29
Roly Poly's Avatar
Roly Poly
You'll need image processing unit B. If you have only the rear backup camera then you only have image processing unit A installed. You can also check via Forscan to see if you have only "A" or both "A and B". Image processing unit "B" is used by the 3rd brake light camera and the trailer add on camera.
If if someone knows how to add "B" I'd be interested.
Roly
Old Mar 1, 2018 | 04:44 AM
  #30
JeepPuller's Avatar
JeepPuller
This is a good idea...subscribing.
