Lowering rear end
Old Aug 28, 2018 | 03:31 PM
  #346
Norris McCarty's Avatar
Norris McCarty
Just finished installing PMF 1 1/2" 2.5 degree blocks on the rear of my 2018 F250 SWB 6.7 4X4 Lariat. I had previously installed the 2"OEM blocks(no degree angle) and experienced a driveline vibration around 60mph. I now have zero vibration! It's my thought that the rear axle assembly needs the 2.5 degrees to match the angle of the driveshaft coming from the transfer case. I know there are others that had installed the 1 1/2" 2.5 degree blocks and experienced a vibration, but happily that is not so in my case!
The truck really looks good with only 1/2" rake back to front plus it should now fit in most all parking garages even with the 12.50 35"X18" Ridge Grapplers.
VERY PLEASED!
Old Aug 28, 2018 | 07:34 PM
  #347
Toohigh's Avatar
Toohigh
VERY PLEASED!
Norris
super helpful Thanks. My parts arrived today.
I assume you you had about a 2 inch tailgate drop?
Old Aug 28, 2018 | 07:57 PM
  #348
Norris McCarty
Yes....right at 2” drop at tailgate from stock...I love it!
Old Sep 1, 2018 | 10:56 AM
  #349
Martin6's Avatar
Martin6
VERY PLEASED!
Was talking to a suspension guy last night about this after I also installed the 2" OEM blocks. After taking some angle measurements we determined my driveline is now around 3 degrees off. He felt that after the driveline starts to wear that I'll develop a vibration. I definitely don't want that so I'm going to order the PMF 2" 2.5 taper blocks with airbag tangs.
Old Sep 3, 2018 | 02:33 PM
  #350
Jimdogsr1's Avatar
Jimdogsr1
Before and after. I took out the stock rear blocks and installed the 1 inch blocks.
Old Sep 13, 2018 | 10:14 PM
  #351
Platdually's Avatar
Platdually
2018 F350 Platinum Dually
Originally Posted by ctimrun
Have an 18 F350 DRW that I would like to lower the back end on a couple of inches (or whatever amount the new blocks give). I read through the thread and it appears as though the DRW trucks need a different block than SRW? What Ford part number should I look for to accomplish this? Can I lower it a couple inches then still use ride rite or firestone airbags for towing or gooseneck?
I looked at my new dually and there are only one inch blocks under the springs, so I don't think it is possible.
Old Jan 6, 2019 | 06:38 PM
  #352
Spooledsrt's Avatar
Spooledsrt
Originally Posted by Moto926
Update
Found some missing weights on a rear tire. Balanced and rotated tires. Test drove new F250 at the dealership. My truck is smoother than the new truck. I'm gonna keep the 1.5" blocks. There is a slightly different engine buzz feel than the new one, but it's hardly noticeable. Just gonna enjoy the truck now.
I would appreciate any feedback from others with 1.5" blocks to confirm the driveline is smooth. Thanks.
Any after pics?
Old Jan 6, 2019 | 06:40 PM
  #353
Spooledsrt's Avatar
Spooledsrt
Did you use the PMF 1" blocks 2.5*?
Old Jan 6, 2019 | 07:36 PM
  #354
Jimdogsr1's Avatar
Jimdogsr1
1 inch blocks.
Old Jan 6, 2019 | 07:42 PM
  #355
Spooledsrt's Avatar
Spooledsrt
1 inch blocks.
the 2.5 degree or flat?
Old Jan 6, 2019 | 07:48 PM
  #356
Jimdogsr1's Avatar
Jimdogsr1
They are flat.
Old Jan 6, 2019 | 08:09 PM
  #357
Spooledsrt's Avatar
Spooledsrt
They are flat.
Thank you. Any vibration?
Old Jan 7, 2019 | 12:23 PM
  #358
Don Schuler's Avatar
Don Schuler
Replaced my block 8 mo ago put 4k towing a camper no problem ,just added rear sway bar have not towed with it yet next week
Old Jan 7, 2019 | 11:32 PM
  #359
Jimdogsr1's Avatar
Jimdogsr1
No, vibration.
Old Jan 17, 2019 | 04:11 PM
  #360
Bmain0407's Avatar
Bmain0407
Rear blocks
Can you send me Vin for your truck? I found in airlift manual for installing rear bags they had two different trucks in pictures. One was a 18 350 dually with shorter blocks other was like mine. I want to lower rear of my 250 with those blocks but I can't get part number without Vin. I'm going to use airbags to keep truck level when I have my 5th wheel hooked up.
