Fall mod/upgrade session has begun
I used to have a ranger that the bolts would not stay tight. I eventually drilled all the way through, used a longer bolt and put a nit on the back side.
In addition, if I feel that the weight is too much or the bolts do not seem to be holding I will remove the starter and drill out the spot on the face of the starter for the 3rd bolt.
The mounting surface on the Denso starter is 15mm.
The hole depth in the transmission case is 25mm.
Clearly the best bolt size to go all the way to the depth of the mounting holes are 40mm, but don't forget about the locking washers which are about 2mm. I am going to use 45mm bolts and the lock washers to securely mount the starter to the case. If I feel the bolts are slightly too long, I will put a flat washer in the mix as well to bring the bolt through distance down a bit, but I don't think 3mm is going to hurt anything.
All three holes in the case go through to the other side. Although, the bolt started to bind up a bit on the outside of the top hole. Probably because there is 18 years of dirt and crap up there.
I did get the wires connected with the help of a floor jack, then got the starter mounted. I put the starter up first and thought there was no way I was going to have an easy time with mounting the wires, so I took it down and used the jack as a third set of hands. Worked pretty well as there is more than enough slack in the wires to do it this way.
This is a picture of a 50mm bolt in the top mounting hole with about 2-3mm sticking out the back of the hole. You can see that there is about 25mm left on the bolt that is available threads.
This is the mounting surface of the Denso, clearly right at 15mm.
The top bolt is the same as this one and I feel this is the best outcome possible for mounting the Denso starter. Thanks to BBD for recommending new/longer bolts.
I got a great deal from Alan who ownes Kankakee Starter and Alternator in Kankakee IL. He is a top notch rebuilder and he sells New Densos
18159393590
BBD
I tightened them up, then wiggled the starter (which shook the truck) while putting a bit more torque on the bolts to ensure the washers were fully compressed. Then I gave them one more good attempt to take out any slack left over. I am sure you could run the threads right out of the case if you went all King Kong on them, but they felt very solid and had a lot of bite.
When grabbing onto the starter to check for how solid the mounting points are, the truck will shake a bit if I move the starter.
I am very confident this is the right combination of bolt length and hardware.
Now on to replacing the high pressure steering hose and the steering gear. Then the 2wd LOW mod and GPR light mod. Once I get the hose and steering gear done, I plan to take a video of the truck starting and compare the difference between the before and after.
Thanks for all the pictures.
On my truck, since I have the automatic transmission, both the upper and lower bolts do not go all the way through because the transmission housing is in the way.
I used 7/16 x 1.5" with course thread flange bolts that are grade 8, but grade 5 would have been okay too. The Bolt is not the weak link the aluminum alloy plate is...
Again, Nice Job MSgt.
Big
Black
Dually
Big
Black
Dually
The nice job credit goes to you my friend. I would have more than likely just put the OEM bolts back in and they would have gone maybe 1/2 way through the mounting holes. Because the bolts go all the way through now, the starter is securely mounted. I would almost guarantee that with the OEM bolts there would have been problems down the road somewhere. Although, I am not an engineer and that is only my intuition. Maybe it would have taken a year, maybe 3, but comparing a 30mm vs a 45mm bolt, there is a drastic difference in thread count and bite into the mounting locations.
Thanks again BBD, I appreciate you posting the advice prior to installing the starter which allowed me to have a successful install.
I'll through my hat in for Rudolph's needs:
Diagnose Glow Plugs- With the GPCM connected it seriously pulls the batteries down. Glow plugs were replaced November 2012, but need to ohm them out.
Leaking HPOP- More than likely leaking from the non-serviceable plug.
Leaking front cover- Slow leak, but will have to be fixed when I pull the engine sometime in the Spring.
Trans flush
UVCH- Need to get OEM part, used Dorman last time (shame on me)
Injector reseal and maybe upgrade to 80% nozzles
Steering gear installed.
High pressure steering hose installed.
Batteries installed.
The Denso starter and batteries turn the truck over at least 2x faster, probably more like 3x times faster. I have a couple of short videos, but need to edit them and do them up right. Once that is done (probably tomorrow) I will post the link to YouTube.
As a teaser, here is a picture of the alternator and batteries in the truck.
