Leveling Pros/ cons recommendations
Old Jul 7, 2017 | 02:57 PM
  #61
user 474747383's Avatar
user 474747383
LOL Now that I look at it may be their there backwards. Nah
Old Jul 7, 2017 | 03:01 PM
  #62
user 474747383
Here's their Pic of what I thought I bought.
Old Jul 7, 2017 | 03:23 PM
  #63
afacey's Avatar
afacey
did they make any difference? You still running 1.5" spacer?
Old Jul 7, 2017 | 03:26 PM
  #64
user 474747383
This truck has a 2" lift, and not that I could tell.
Old Jul 7, 2017 | 04:26 PM
  #65
Tricon's Avatar
Tricon
If I remember correctly, mine look like the ones in the Carli picture. I didn't have any issues with them hitting anything... To be honest I don't think it will really matter though.
Old Jul 7, 2017 | 04:28 PM
  #66
Tricon's Avatar
Tricon
Ha, you might actually have em on backwards... Still... Don't think it matters.
Old Jul 7, 2017 | 05:22 PM
  #67
user 474747383
I talked to Carli and they said they need to correct that problem and to remove them or cut the bolts, they could sheer off in a bind.
Took them off and returning them.
Old Apr 4, 2019 | 10:00 AM
  #68
Mykroft77's Avatar
Mykroft77
Originally Posted by KubotaOrange76
Thank you, truck looks great, May go this route with mine until I up to 37's. 1-1.5" will still be enough rake for what i pull 80% of the time for me to be satisfied
Removed the rear block from my f150 and got similar results, been very happy with it
If I go for removing the block completely is there anything special I would have to do to the leaf or axle to seat it properly or can I just put a new shorter u-bolt in there and tighten it down just as it was (just without the block). I do plan on replacing the bumper above the axle with an airbag eventually as well.
Old Apr 4, 2019 | 10:53 AM
  #69
rtmhunter's Avatar
rtmhunter
BDS or Ready Lift to level the F350? Hearing good things about both. Anyone have any real world experience they want to share? Just can't decide which way to go.
Old Apr 4, 2019 | 11:04 AM
  #70
NL_F250's Avatar
NL_F250
I went with the BDS 2" on my 250, still en route and I should have it installed in 3 or 4 weeks, next turnaround.
From a lot of the looking I did, the ride quality was basically unchanged, and a great way to go if you just want to run 35's and have it looking a bit beefier. I went that route as I didn't want to tangle with shock extensions, and wanted proper sized shocks. I also favored the BDS spring spacer, as it sits below the spring on the perch, rather than the ReadyLift TopHat style on top of the spring. Personal Preference.
Old Apr 4, 2019 | 11:36 AM
  #71
rtmhunter's Avatar
rtmhunter
Which one did you get? Did you ad anything extra to your kit? That's exactly what I want. Same ride (rough enough already on a F350) with a beefier look and leveled out. I know little to nothing about what to order. I have a shop lined up for install just a matter of getting the right kit and any ad-ons that are necessary. Thanks.
Old Apr 4, 2019 | 11:54 AM
  #72
NL_F250's Avatar
NL_F250
Canadian Site:
https://bds-suspension.ca/bds-suspen...-bds1519h.html
US:
2017-2019 Ford F250 / F350 8"" lift kit 1541H | BDS Suspension
I didn't add any extra parts. Track bar bracket should correct the axel and that's about it. From everyone I spoke to on here that went that route, they were pleased with the end result.
The other kits have bump stop extensions, sway bar drops and brake line brackets, but all those I've spoken to, including my CAD distributor, say they're not required for the basic 2".
The only thing I'll likely end up doing is getting 4" or 4.5" blocks in the rear to maintain around ~2" of rake. I run bags with the sled deck loaded up, but I didn't want the perfectly even look.
I was going to go with the 2.5" Radius Arm kit, which includes new coils and radius arms, but I dont really offroad, only to get to somewhere to drop my sled off the deck, so I think it would have been overkill for me. It was also a price difference of about 1300 CAD. At that point, the pricing was the same as a 4" lift, but I run my stocker 275/70/18 in the winter, and have no interest in running 37s, so it wasn't too appealing to me.
If I'm not satisfied with the ride I'll certainly ly go that route, bit I don't think I'll have any issues. I just wanted something to get ride of the nose squat look, just off level, that complimented the look of the 35's.
Old Apr 4, 2019 | 01:43 PM
  #73
rtmhunter's Avatar
rtmhunter
Thanks you very much for the information. Looks like I'll be spending some money soon.
spocky1187
May 29, 2020 10:46 AM
Mtncrash1
Feb 13, 2015 09:07 PM
guin7714
Apr 9, 2012 09:20 PM
93f150guy
1997 - 2003 F150
Mar 22, 2010 12:24 AM
donbeeler49
2004 - 2008 F150
Apr 12, 2008 03:05 PM
