2 2 1/2 Leveling kits
Old Apr 12, 2008 | 09:56 AM
donbeeler49's Avatar
donbeeler49
Ok, what is the real truth about offset vs non-offset front leveling kits? I have a 2007 FX4 reg cab flareside. I want it level without problems. Comments please? The more comments, the better I'll feel. Thanks.
Old Apr 12, 2008 | 11:50 AM
mattd17's Avatar
mattd17
the offset only hleps prevent the upper control arm from hittinf the coil spring. as far as being truly level, sometimes it is a gamble. you can take 2 identical trucks, install identical leveling kits, and get different results. most people are the happiest with the 2" kit. if you get the 2.5", then you will most likely want to also look into something for the rear, such as an add-a-leaf, or bigger block, or air bags. how often do you tow or haul stuff? a 2.5" kit without any mods in the back and tows a lot, will definately appear nose up a lot.
Old Apr 12, 2008 | 03:05 PM
Fosters's Avatar
Fosters
mine has the 2.5" and it still isn't level. so yeah, as you said, your results may vary...
stircrazy05
2004 - 2008 F150
Apr 25, 2021 05:17 PM
cattlerancher
2004 - 2008 F150
Jul 13, 2011 07:01 PM
cm351f
Apr 3, 2008 04:23 PM
jvoigt
Jul 23, 2007 11:05 PM
99stroke
Aug 20, 2003 04:13 PM
