Turbo build
Old Mar 20, 2017 | 08:43 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by ExPACamper
Wow, 30-35lbs is a LOT of boost on a stock turbo! I thought they started to get really inefficient (and HOT) above 30psi?
They do. Plenty of turbo talk and education in the threads below if you have 2 weeks to read it and digest the information.
https://www.ford-trucks.com/forums/1...houghts-3.html
and
https://www.ford-trucks.com/forums/1...nsmission.html
Old Mar 23, 2017 | 01:53 PM
P4IN COMM4NDO's Avatar
P4IN COMM4NDO
Got the Diamond Eye 4" Aluminized Downpipe, 360 rebuild, billet compressor wheel, and a new 6637 filter, decided to try donaldson this time. Only $10 more and they are claiming like 37% more airflow then the standard one. Plus there is a Donaldson plant near me so Im sustaining local employment and supporting riffraff all in one xD.
Playing the exhaust by ear. Not sure if I want to use the stacks I got, run an axle dump, or have it exit on the passenger side behind the rear door. I may just leave it at the downpipe haha. Nice n loud.
Hopefully these turbo parts are all theyre cracked up to be, $380 bucks. . .
Old Mar 23, 2017 | 03:08 PM
ExPACamper's Avatar
ExPACamper
Sounds like you are on your way!
Have you run any data logs on your truck yet? If not, it's time...before you get too deep into the mods, get a solid baseline and make sure she is solid and happy. A good foundation makes a strong house.
Oh- and pics- we need PICS! I think it's a rule that once you pass $300 in mods you are required to post some pics
Old Mar 23, 2017 | 04:22 PM
brian42's Avatar
brian42
Veteran: Navy
I was going to do an axle dump when I got my MBRP but it requires the spare tire to be removed from the OEM location. I was not interested in relocating the spare so I went with the original side exit location.
Old Mar 24, 2017 | 10:48 AM
P4IN COMM4NDO
Oh yeah!
I have run data logs for troubleshooting, hadnt thought to do it when there isnt anything wrong. . .
I passed $300 a loooooong time ago haha. I got at least 1k under the hood, with another $1600 ish on the outside. . . I got pics, what do you wanna see???
Welp, Im planning to cut out the spare tire rack anyhow cuz I got a shortbed and that 29 gallon tank SUCKS. Gonna throw a longbed tank in there. So I wouldnt have that getting in my way. I will eventually do a tire rack either on the roof (i think it looks cool, cant imagine how much it kills mpgs. . .) or a rack in the bed depending on what I do for exhaust. I currently dont even run a spare. I need to get one ordered sometime. . . I have AAA so I can just call a tow truck for a ride home
Old Mar 24, 2017 | 03:52 PM
Bonanza35's Avatar
Bonanza35
All good information here. But this is the first I heard that the AIS flows 50% more then stock. I've never seen that. I know it has the fender sleeve if you install it, but not sure that filter flows that much. It's a very good replacement filter over stock, just never seen that write up.
Old Mar 24, 2017 | 04:05 PM
coax9952's Avatar
coax9952
Oh yeah, that was a major thread some time the middle of last year, Everybody was there, and boatloads of Data was shared for at least a week. But of course I couldn't find it if my life depended on it now. The bottom line was ANYTHING, flowed better than the stock box....I'm still trying to find it.
Old Mar 25, 2017 | 02:13 PM
Bonanza35's Avatar
Bonanza35
Hope you find it. I've been here a while and never saw it.
Old Mar 26, 2017 | 01:30 AM
coax9952's Avatar
coax9952
Well, Let's see, some mundane chatter here......
https://www.ford-trucks.com/forums/1...lter+Flow+Data
Then another nugget here:
https://www.ford-trucks.com/forums/1...l#post13748541
Old Mar 26, 2017 | 01:36 AM
coax9952's Avatar
coax9952
A rather old thread, but lots of data being tossed about....
https://www.ford-trucks.com/forums/6...-shootout.html
Oh hell, just go to advanced search and look under "Air Filter Flow data", It's 7 pages long, and my eyes are burning......
Old Mar 26, 2017 | 01:02 PM
Bonanza35's Avatar
Bonanza35
Yes I've seen all these but no apples to oranges on these. You have to compair boost numbers at equal engine RPM's threw out to see real numbers. The AIS was designed to filter better then the stock set up. Not 50% more flow. The e99 only had the fender sleeve. The next year it changed to the front. Using both don't equal 50% more flow. The insert will only flow so much. More pressure more being forced threw. Just not as efficient as it could be. Anyway, that's my opinion, didn't mean to get off track here. Just wanted to set straight what I thought and many others.
Old Apr 3, 2017 | 10:09 PM
P4IN COMM4NDO
Im close on turbo extraction, just the one clamp on the backside.
I went ahead and got some plenum reinforcements, clamps, and new boots. Also got some pedestal O rings.
If I have any boost leaks after this I have no clue where theyd be coming from
Old Apr 4, 2017 | 04:57 PM
  #28
Bonanza35's Avatar
Bonanza35
Plenums there self between block and plenum. Factory doesn't use enough sealant there and it will blow out after time. I removed mine and resealed with a bigger bead and reinforcement rings and no more leaks. I did use OEM sealant also.
Old Apr 4, 2017 | 09:11 PM
  #29
P4IN COMM4NDO
Hmmmm. . . So I just pull the plenums and put some motorcraft grey RTV on them?
Old Apr 4, 2017 | 09:14 PM
  #30
z31freakify's Avatar
z31freakify
Yes but prep is really important a nice clean surface will insure a properly sealed plenum. Or buy the riffraff billet plenums with come with an O ring and no more goop needed.
