Turbo build
Old Apr 24, 2017 | 07:36 AM
  #46
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Lets make sure we are keeping the acronyms straight.
EBPV - Exhaust Back Pressure Valve
EBPS - Exhaust Back Pressure Sensor
Old Apr 24, 2017 | 11:57 AM
  #47
P4IN COMM4NDO's Avatar
P4IN COMM4NDO
Originally Posted by Dan V
That sensor on the front of the engine?....kinda important to operate correctly.
It was like that when I purchased it. I honestly have no idea what purpose it serves. I just know it's there lol. One of those things I keep meaning to sit down and go over but never do.
Old Apr 24, 2017 | 12:52 PM
  #48
Dan V's Avatar
Dan V
As Tugly would maybe say....it acts as a load meter, and in addition it has some function to the shift characteristics of the 4R100 trans.
Old Apr 24, 2017 | 09:29 PM
  #49
P4IN COMM4NDO
Ok. Well I'll look into it before I throw it back on the road. Where is the tubing supposed to end up after the sensor?
Old Apr 25, 2017 | 06:24 AM
  #50
Walleye Hunter's Avatar
Walleye Hunter
The tube runs between the front of the passenger's side exhaust manifold to that sensor. It follows fairly close to the block and it is hard to tell which end of the tube goes up but if you don't have it right it won't connect. The job is a little tricky but not bad. When attaching to the sensor use a wrench to hold the mount still or you'll bend up that mounting plate and earn an oil leak. There should be a nipple sticking out of the front of that manifold and you might even have some of the other end of the tubing still attached.
When I fixed mine I saw no improvement and I'm curious to hear how yours does.
Old Apr 25, 2017 | 09:24 AM
  #51
P4IN COMM4NDO
​​​​​ok. I I can use 5/16 brake line right? For some reason I remember that being the size
Old Apr 25, 2017 | 10:10 AM
  #52
Dan V's Avatar
Dan V
So you'd rather spend how much time forming a piece of brake line than spend the $50 for this?
EBP Tube
Old Apr 25, 2017 | 10:12 AM
  #53
brian42's Avatar
brian42
Veteran: Navy
It looks like this:
Exhaust Back Pressure Tube EBP 99-03 - Riffraff Diesel Performance
Old Apr 25, 2017 | 10:44 AM
  #54
Walleye Hunter
I don't know but 5/16 sounds close and if you got fittings that work it should do. I'm all for making stuff for less and customizing new stuff a little but that tube is a bear when you have one that is made right, I'd expect it to be difficult to bend it right to fit where it has to go.
Old Apr 25, 2017 | 12:09 PM
  #55
P4IN COMM4NDO
EBP Tube
plus $17 for shipping. . . I havent had a chance to look at it yet so I didnt know what I was dealing with. . .
Originally Posted by brian42
Thanks
Yeah thats what Im hearing. . . Ill give it a go before I order one.
Hopefully the sensor is still good. And hopefully I can track down the plug. . .
On a different subject, looking at my old downpipe compared to my new one. I noticed that the factory one has some heat shield deal, I assume I need to recreate that on the new one? Or maybe Ill just tell my passenger its a custom foot warmer lol
Old Apr 25, 2017 | 12:19 PM
  #56
Walleye Hunter
Here it's a little cheaper, $8.00+- for shipping. They call it an EGR tube but that's the part number for it.
http://parts.autonationfordwhitebear...rd/1c3z9d477aa
Old Apr 25, 2017 | 02:03 PM
  #57
Bonanza35's Avatar
Bonanza35
I didn't use the heat shield and it's fine. It's up to you. The wife puts all kinds of things down on the floor and it hasn't been a problem.
Old Apr 25, 2017 | 07:56 PM
  #58
hav24wheel's Avatar
hav24wheel
No heat shields on my stuff either, no issues.
Old Apr 25, 2017 | 09:22 PM
  #59
P4IN COMM4NDO
OK, sounds good. Didnt really think I would need it, I figure its got enough space between the pipe and the floorboards moving at road speeds should keep everything cool. Just wanted to make sure, plus I didnt really feel like messing with it lol.
Getting some of the turbo back together, finally got all the clearcoat on it.
Old Apr 25, 2017 | 09:35 PM
  #60
z31freakify's Avatar
z31freakify
WHERES THE PICTURES!!!!! Come on man you now this ain't a thread without pics lol...
