Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread part 3-2017
Old Dec 20, 2018 | 11:07 PM
  #11161
Steve GG's Avatar
Steve GG
Good evening y'all.. spent some of my night dancing with the pressure washer. Had to go get 100% gasoline and a circular spray head for the wand ..
Old Dec 21, 2018 | 12:44 AM
  #11162
Fomoko1's Avatar
Fomoko1
Hello Steve, just woke up in time from my little nap to go to bed now.
Good nite Steve.
Old Dec 21, 2018 | 12:50 AM
  #11163
privateer, eh's Avatar
privateer, eh
At this point Morris I'm going to chase down the varnish problem, I run an inline filter and put it on where I can see it between the deck and the cab, it's full and clean. I'll open up the throttle and spray the jets and area with brake cleaner and then disconnect the fuel line at the filter and flood the filter with brake cleaner. I was going to do this but I don't have that plastic straw that goes into the spray nozzle. Brake cleaner dissolves the dirt and varnish and breaks it down. After that I'll spray it with carb cleaner using the straw and same procedure and hook everything up again. Carb cleaning farmer style, a float bowl full of brake and carb cleaner should clean out those jets and save me tearing into that part of the carb. Most carbs need to be cleaned out but not adjusted in order to bring them back into tune, avoid using the screwdriver unless it's actually needed. Hopefully this will straighten everything thing out. The inline filter catches the dirt but it doesn't catch the varnish so that's probably the problem as my vacuum lines are okay. If this doesn't work then I'm chasing a diaphragm but I doubt that as it not leaking fuel.
Carb doesn't idle - dirty jets or vacuum, maybe EGR.
Carb leaks fuel - bad gasket or diaphragm
Carb still doesn't work right then either open up and clean or take a screwdriver to it.
Always make sure your filters are okay first and your vacuums are okay first before doing anything.
Run an easy to check inline filter. Mine costs under $5 and take under 5 minutes to change even on the side of the highway, just need a blade screwdriver and another filter which is in the glove box.
Old Dec 21, 2018 | 08:33 AM
  #11164
yamagrant's Avatar
yamagrant
Happy Friday Mornin'all. 1 truck left to load, but the Christmas rush is over, and he probably will come home empty. have a great day guy's.
Old Dec 21, 2018 | 09:00 AM
  #11165
Steve GG's Avatar
Steve GG
Good morning Morris, Perry, Grant and wandering misfits. .
Old Dec 21, 2018 | 09:12 AM
  #11166
56panelford's Avatar
56panelford
Good morning all..
Old Dec 21, 2018 | 09:16 AM
  #11167
Steve GG's Avatar
Steve GG
How do John..
Old Dec 21, 2018 | 09:27 AM
  #11168
56panelford
Not bad Steve,good news is they arrested the criminal ba$stard across the street and he's back in jail..even got to watch it on camera....lol
Old Dec 21, 2018 | 09:44 AM
  #11169
Steve GG's Avatar
Steve GG
That does seem like good news.. and your camera system let you enjoy the show... Your own "PD Live"....
Old Dec 21, 2018 | 09:50 AM
  #11170
56panelford
The police have been watching very close and apparently he was on a curfew and was spotted getting home past the 9 o'clock time limit..
Old Dec 21, 2018 | 09:54 AM
  #11171
Steve GG's Avatar
Steve GG
They must of had another reason to have kept a close eye on him..
Old Dec 21, 2018 | 10:42 AM
  #11172
56panelford
All he has ever done in live was steal and as soon as he got out of prison and back in town the thieving began, he's also a dope peddler and a meth head
Old Dec 21, 2018 | 12:00 PM
  #11173
Steve GG's Avatar
Steve GG
Sounds like he needs permanent residence in the pokey...
  #11174
Fomoko1's Avatar
Fomoko1
Hello John, Grant, Steve, Perry and all who lurk here. There were a few sprinkles of rain last night, the roads were wet this morning but it didn`t freeze. Lots of windshield washer needed. Weird that a plane slide off the runway on take off. How are your roads John?
Thanks for the tips Perry.
Strange that the the Christmas rush is over already Grant, I still haven`t quite finished my the last of my Christmas shopping.
Are you already for Christmas Steve?
Old Dec 21, 2018 | 12:02 PM
  #11175
56panelford
He needs to be thrown so deep in a cell that he gets fed by a sling shot...lol
