No topic thread part 3-2017
Dec 20, 2018 | 03:41 PM
I've got a box I plan to restore next summer when I can get it outside to sandblast..also have ash boards to mill too
Dec 20, 2018 | 04:07 PM
If this box turns out better than the two I have then I might sell them both John.....if I don't make a matching trailer. Heavier welding like trailer frames I can fake my way through.
This fuel that we have nowadays evaporates from the carb faster overnight than the old fuels from when everything was carburetored, it also gunks up in the float bowl. Hopefully a good cleaning will help with the way it runs.
Dec 20, 2018 | 04:10 PM
It not only evaporates way faster, it turns to real nasty varnish at the bottom of the carb....got to love progress, not!
Dec 20, 2018 | 04:12 PM
Its a good thing that this is the 2150 2 bbl carb, probably the easiest one there is to clean up and work on.
Dec 20, 2018 | 04:17 PM
And a bit cheaper for a kit too.
Dec 20, 2018 | 04:20 PM
If this doesn't work I'll replace the filter at the carb as it may be blocked by varnish
Dec 20, 2018 | 04:45 PM
That's what I always start with now. One time a fuel pump that put out way too much pressure, we couldn't figure out why the carb kept flooding.
Dec 20, 2018 | 04:49 PM
I always make sure I put premium gas in the tank at the end of the season and a bottle of Seafoam and run it through the system. My panel I always burn premium
Dec 20, 2018 | 05:06 PM
That's great idea John. I use premium in the Mustang and the 64 XL. Do you use an zinc additive in the oil?
Dec 20, 2018 | 06:14 PM
Right now I'm got a low idle and when it warms up I get surging along with the low idle.
Dec 20, 2018 | 06:32 PM
Quote:
Originally Posted by
Fomoko1
No additives Morris...
Dec 20, 2018 | 08:09 PM
privateer, eh
I have to have full choke and pump the gas lots to get the F600 to start, once it warms up well it`ll run without the choke.
56panelford
I`m worried about wiping out the cam since zinc was removed from engine oil.
Dec 20, 2018 | 09:13 PM
I have a new motor in my panel and the one in the pickup is an 83. What's in yours.?
Dec 20, 2018 | 10:28 PM
1980 Mercury car 302/C4, from the same car as the front clip John.
