Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
No topic thread part 3-2017
Old Nov 12, 2018 | 06:53 PM
  #9961
privateer, eh's Avatar
privateer, eh
Picked up the siding and trim for this job and the customer took me for a midday meal at the Crowfoot diner, not as good a meal as it used to be but the management has changed in the last few years.
There's talk of +12 or better tomorrow.
Old Nov 12, 2018 | 08:03 PM
  #9962
56panelford's Avatar
56panelford
Polished up parts of the panel today, think I may have burned through the clear coat in one spot, not sure yet..
Old Nov 12, 2018 | 08:29 PM
  #9963
privateer, eh
If you use the reflection from the bulb of a florescent light on that panel you'll be able to see a dip in the clear coat in that area. I use the shadow from the rake handle when I'm doing grading, if it dips its low and if it rises its high. Shadow lines are a landscapers best friend when you're making and reading a grade or making sure a yard is smooth enough for sod. There's no puddles in my yards.
Old Nov 12, 2018 | 08:31 PM
  #9964
56panelford
I'm pretty sure I did, looks flat at the edge of the cowl where it meets the door..
Old Nov 12, 2018 | 08:36 PM
  #9965
privateer, eh
Did your pad pick up any paint, if not you should be able to redo the clear on that side of the body line on the panel and re buff it.
Old Nov 12, 2018 | 08:40 PM
  #9966
56panelford
Problem is I filled all my body lines so would have to do more than I really wanted to. I hate the thoughts of pulling my fenders again so will leave it for now and see what happens..might be able to blend it where it's not too noticeable until it starts to look chalky in a couple years..
Old Nov 12, 2018 | 08:45 PM
  #9967
privateer, eh
Build it up with lots of wax, lol. The part I wouldn't like is having to mask off the whole vehicle in order to clear coat 1 panel, flames or scallops on the drawing board, LOL.
Old Nov 12, 2018 | 08:47 PM
  #9968
56panelford
I have to re-clear the door on the other side when I patch that small blister in the paint, I'll consider doing it then..
Old Nov 12, 2018 | 08:51 PM
  #9969
privateer, eh
That'll make the job more worthwhile doing.
Old Nov 12, 2018 | 08:54 PM
  #9970
56panelford
I'm going to do the patch but not paint and clear until the spring just before I'm able to take it out so have a while to think it over...lol
Old Nov 12, 2018 | 09:18 PM
  #9971
Steve GG's Avatar
Steve GG
You don't want to rush into it..
Old Nov 12, 2018 | 09:20 PM
  #9972
56panelford
Not even sure when I'm going to start the patch Steve, it's one of those things once you start you have to finish it...lol
Old Nov 12, 2018 | 09:28 PM
  #9973
Steve GG's Avatar
Steve GG
I figured that might be the reason for hesitation.. I am getting a little rust on the lower inside of the door on my truck.. Guess I might have to look at doing a little sanding and painting..
Old Nov 12, 2018 | 09:32 PM
  #9974
56panelford
I'll likely start the patching soon but think I'll take a break for a little bit..
Old Nov 12, 2018 | 09:34 PM
  #9975
Steve GG's Avatar
Steve GG
I don't blame you.. You have been rather busy with things lately...
