Trailer Camera and TPMS Kit
Old Feb 26, 2017 | 06:32 PM
  #121
Robeleo's Avatar
Robeleo
Just received Y harness and powder box on Thursday, I'm out of town so here is some pictures of Y harness and I'm waiting to get pictures of powder box
Old Feb 27, 2017 | 03:09 AM
  #122
Rasalas's Avatar
Rasalas
Originally Posted by danr1707
Not sure. Maybe try looking with a flashlight?
The plug is tucked in up high but you do not have to lower the tire, but it would make it easier to retrieve. It has a cap on the end to keep contaminants out. Once you have done it once, then next one would be easy to find.
Old Feb 27, 2017 | 11:10 AM
  #123
4dogdoc's Avatar
4dogdoc
As far as this aftermarket box to move the camera plug to the bed, is there no concern about the steel box making contact with the aluminum bed? I thought this was a potential problem with any add-ons.
Old Feb 27, 2017 | 11:14 AM
  #124
STOF-FORD's Avatar
STOF-FORD
I think it's a fair question as I had wondered about the same. I am planning to cut and place a thin rubber gasket between the two, just to be on the safe side. Since I don't yet have my truck, I don't know if the OEM bolts already supplied are aluminum or steel. In either case, whatever Ford used for the screws, should still be ok, I would think.
Old Feb 27, 2017 | 11:47 AM
  #125
Robeleo's Avatar
Robeleo
I had bed liner in my truck from dealer, or where they send the trucks for it, and they removed everything in bed to spray bed liner, hooks, trailer plug, screws, I think better and thick that factory install, so I have bedliner between aluminum and box but I will do the same just in case, some rubber between and same screws
Old Feb 27, 2017 | 11:54 AM
  #126
STOF-FORD's Avatar
STOF-FORD
Yah, I will have the spray in bed liner as well, but better safe than sorry. I'm going through a similar process for bolting down my steel truck box in the front of the bed. I will have fiber insulators through the holes in the bed and fiber washers above and below, under the bolt head and above the nut and washer. I'm more concerned about that one as it is where water will stand, and water is the catalyst for corrosion to take place.
Old Mar 24, 2017 | 02:05 PM
  #127
dsdavidson's Avatar
dsdavidson
I have purchased the trailer camera and tpms option and am not very happy with this as it does not work well for 5th wheels. I am looking to move the camera plug to the bed and noted your comment on an aftermarket product. Do you have more information on this?
Old Mar 24, 2017 | 02:10 PM
  #128
System's Avatar
System
Prolocutor
You need a wire extension and the mounting box. Both sold here. Easy plug and play if you don't want to do your own wiring and fabrication...
https://nicholsmanufacturingandweldi...sPage=products
Old Mar 24, 2017 | 08:20 PM
  #129
tjkadar's Avatar
tjkadar
I used the Nichols Manufacturing option and it worked very, very well.
Old Mar 26, 2017 | 11:19 AM
  #130
STOF-FORD's Avatar
STOF-FORD
I'll second that! Very happy with the Nichols solution, and I can't imagine anyone having better customer service and communication. Well worth the price!
Old Mar 26, 2017 | 11:20 AM
  #131
dsdavidson's Avatar
dsdavidson
Thanks for the info on Nichols Manufacturing. I ordered the new box that accounts for interference due to the factory spray in lining. Should be available next week.
My other issue is the tpms valve stems. These are too small for my wheels. Does any one know if there is a supplier for larger stems or a way to somehow use the ones supplied by Ford?
Old Mar 26, 2017 | 11:25 AM
  #132
STOF-FORD's Avatar
STOF-FORD
Nichols did have the larger stems on their site. Not sure if they are still there or not.
Old Mar 26, 2017 | 11:54 AM
  #133
dsdavidson's Avatar
dsdavidson
Yes! I see it now on the Nichols site. I will order this right away, thanks.
Old May 6, 2017 | 09:17 PM
  #134
alex56mclean's Avatar
alex56mclean
so ford TPMS can work with steel belt tires!!
I posted to AS forum that the instruction/installation details explicitly excluded steel carcass tires, but it seems that at least one of us has tested the theory and found it without merit. I have the same trailer as OP, a 2017 Classic AS with Michelin LT 225/75R16 tires. I expect same as OP. These are promoted as having two steel belts to benefit something or other....Anyway. Pretty disappointed that Ford cannot refine their guidance on a pretty critical towing monitor. I have purchased an alternate aftermarket device. Reading interest from this forum on same question, I thought I would join and post a partial answer. The key is at end of post. A user of steel belted tires is experiencing no problems with TPMS trailer use. As a few of the enlightened on this forum have speculated, but did not have data to confirm.
Quote:
Originally Posted by a1ofm
This is an exact quote from the Ford installation instructions. Pretty bummed, since my new F250 superduty has the integrated system that would let me avoid another monitor in the cab. Was one of the key features I wanted in my TV. Checking on the Ford forums, there is a mixed view on whether the system would work fine in most cases, and it's just Ford making sure they CYA. But also some folks speculate that this steel can mess up the signal transmission. I'll keep up to date on this topic, but I'm not spending the money and hassle of install, only to then have to live with non working system. My Michelin LT tires have two steel belts as well as polymer cords......will buy an alternate TPMS probably the simple flow through design. Anyone got strong opinions on various options??
Alex
Not sure if the tires on our 2017 Airstream Classic are steel belted or not but the TPMS does work for us.
Old May 7, 2017 | 09:37 AM
  #135
STOF-FORD's Avatar
STOF-FORD
Alex
Just to add my experience. I just recently switched out tires on my 43' 5ver. I went to Goodyear G614's which are not only steel belted, but also have steel reinforcing in the sidewalls. I believe this is the definition of a steel carcass tire, but I could be wrong. While switching to the new tires, I installed the Ford trailer TPMS sensors that came with my '17 F450. All six sensors work perfectly with no problems! There had been some speculation that the bead on steel carcass tires would be too big to allow room for the sensors, but that was not an issue. There was plenty of room and no difficulty in mounting to my cast aluminum rims.
I hope this helps all who are wondering if they will work or not.
