Trailer Camera and TPMS Kit
#76
I was working on it today, I have the camera temp mounted to my ladder. may finish tomorrow, I will need to cut and splice the cable as it is twice as long as my trailer. And I dont want to bundle that much cable under the trailer. This is what I have found so far for the trailer end plug
#77
#78
The tire shop I went to today, said the sensor can be swapped onto a different stem that will fit your wheel. They unscrew from the stems.
#79
Mine didn't fit either so I had mine installed at a Discount Tire shop by "banding" them inside the wheel well like the old school TPMS sensors before they started putting them in the stem. Worked perfectly when we took the 5er out last week. Camera worked great too!
#80
I've asked a couple of places about swapping the stems out like wb6anp mentioned, but no joy there.
#81
it is just a flexible metal band and bracket that holds the sensor in place inside the wheel well. I didn't get a photo when they were installing but if you search on google for "TPMS band" you will see several kits available for sale and I'm sure your local shop could install.
#82
#83
Curious if anyone has purchased extra wheel sensors? In spring when my truck arrives, I will need to buy 2 more sensors for our triple axle toyhauler. I am a little worried about what they may cost.....
EDIT: I was able to track them down at my local dealer, they are about $55.00 (CAD) each.
#84
I asked the Ford Build customer rep if this system could be purchased after the sell and she said it could not. However the link to Ford Accessories she gave me showed this exact same system as an accessory at the exact same price as when you order it. Has anyone purchased one after the fact?
Thanks,
Paul
Thanks,
Paul
#85
#86
#88
Thanks,
Paul
Thanks,
Paul
Are you sure the harness has been factory installed in the truck?
As far as I know harness' are VIN specific. If you didn't order it, the harness isn't there.
Or am I reading your conversation wrong.
#89
Are you guys talking about buying the camera, wiring from the camera to the truck and the 7/12 plug after you've ordered the truck without paying for that option?
#90
