Well, the engine is out and it's finally getting closer to the time to drag the '81 away. I've stripped it pretty bare and there's not a lot left of it.
Soon, I should start the process of pulling the 302 out of my new Bronco and dropping my 300 in its place. Haven't driven it since about March, so I'm getting antsy.
I was sure to grab the frame perches out of my '81 while I was in there as well.
The 302 is fuel injected, so I'm actually planning on keeping it that way. I'm not going to go with the full MPFI setup for a 300, but I am looking to switch to a Holley Sniper. I've been advised on several fronts to go with the 2bbl version, since "barrels" don't really matter on EFI, and it's rated to 580cfm/350HP, which is plenty for my needs.
The Bronco is already plumbed for a high pressure fuel system and all of that, so a lot of the hard work is already done for me.
One question for you guys. Do any of you know of a good way to identify the source of an oil leak when an engine is out? Despite all fresh new gaskets on this engine, it leaked really bad. I don't know where I went wrong.
And, of course, it was dripping down the back of the engine, which means that it could either be the valve cover, oil pan, lifter cover, or rear main. You know, nice and nailed down...
wipe it down good (not using much, if any cleaner) then dust it with baking soda or flour. thru reverse capillary action, you'll see the wet spot reveal themselves. similar to a dye penetrant testing used in NDT techniques. a quick google will show you some cool stuff.
Great stuff [information/idea]. Thanks for sharing your knowledge!
I've read and been told that using sealant on a silicone gasket is a BIG no no.
The reason they use silicone is that it can move and distort as time goes on, filling gaps, and sealing by being able to slip along the surfaces.
If you use sealant, it sticks it in place and completely negates its biggest advantage.
I've heard some of same things; not sure what the answer is. I know you did your best to do everything right. Probably best to do it over same way and hope for the best unless someone can come up with a better idea.
Yeah, that's kinda what I'm thinking. Not my favorite solution, but it might have to do.
I've used two of these gaskets before with good results, so maybe I just got a bad one.
Didn't all the splits occur at the bolt holes? That would seem to imply too much torque, too tight?
On my neoprene v.cover gasket I use weather strip adhesive on one side and allow it to dry. I will most likely, after I research it, do the same with the one piece pan gasket. But that depends on what I find after research, since I haven't used that type of gasket before. I also like to use a 1/4" inch drive ratchet for covers like that so I can really get a feeling for the tightness (is that a word?) of the bolt/nut.
Yeah, that's what it looks like. I know the torque on the oil pan is not all that much, about 16 - 22 ft/lbs or something, and I have a nice, click-type torque wrench.
Who knows, maybe I was reading it wrong and had it one rotation too far, which would set it for 28 ft/lbs when I meant to have it pointing at 18.
I had that problem when I tried to use the one piece gasket on an early year oil pan that is dimpled slightly around the bolt holes to hold the cork gasket in place.
The late model oil pan is flat around the bolt holes.
The aftermarket oil pans I've purchased don't come with the raised ridges, even if you get a year correct pan.
So, it was perfectly flat and ready for a 1 piece silicone gasket.
