Help!!! 6.0 nightmare
Old Aug 17, 2015 | 09:53 PM
  #181
Shaneb75's Avatar
Shaneb75
Strokin Okie
Same here. Ford sells the injector Orings but unfortunately not the NCs. Some have been successful tho.
Old Aug 17, 2015 | 10:10 PM
  #182
dlibson's Avatar
dlibson
This needs to be something where you get the VC off hot and crank over looking at injector tops with a mirror...
Old Aug 17, 2015 | 11:16 PM
  #183
Yahiko's Avatar
Yahiko
Originally Posted by IHateCommieCars
Boys, it's one thing to use anonymous user names to post "expertise" online. But, for Sean to put his have-tools-will-travel butt on the line, in front of this crowd, to help a brother in need - that's some strong stuff. Send me your PayPal, Firefighter, and I'll buy the beer.
This is only the 2nd time I have hit the road to help out. Anthony and Julie are so much
better set up and when they were driving full time it was already loaded into the truck.
You should of seen his parts stash. I think he almost could do a full engine from the bottom up.
One reason I do this is I have been helped in the past and giving back is a good thing.
If more people would do this in the world think where we would be.
Originally Posted by 04badford
Fuel rail nipple cups,OOpS can I say that or will I get bustee by the Mountee, kidding good Effort Sean, hope it didn't put ya out to bad Broutha
Well guess you hit that one right on the head. I had a set of rails with me just in case.
Here is the photo that Firefighter209 sent me while we were on the phone and her husband was doing the testing. Can you see the IT ?
Firefighter209
You may want to look here for some of the IPR % info I was using for the question.
It's really hard to pin a number down but 84% + is a leak. The pump is putting all
it has out with that IRP %
https://www.ford-trucks.com/forums/1...ormal-icp.html
Sean
6.0L Tech Folder
Old Aug 18, 2015 | 11:56 AM
  #184
04badford's Avatar
04badford
BAM, there it is, good Job Guys and Ma'am ,delicate little Oring placement , may want to check the rest of them unless that's the only one leaking, now you can Love your 6.0 again
Old Aug 18, 2015 | 12:00 PM
  #185
Firefighter209's Avatar
Firefighter209
Going to just replace the whole rail. With 2 cracks in the same nipple cup holder I think it's toast. As for loving my 6.0 again, I wouldn't know we bought it not running and have not really had the pleasure yet. BUT we will!!!
Old Aug 18, 2015 | 12:06 PM
  #186
04badford's Avatar
04badford
We'll your in for a surprise,and in good FTE Hands
Old Aug 18, 2015 | 04:54 PM
  #187
Yahiko's Avatar
Yahiko
I will be going over the replacement one I am sending with
the very fine tooth comb before I send it out. That is my project
for the afternoon. I don't want to send out a bad one.
I am not going to have a 2nd crossing issue. So...
Any hints on how I should mark it for shipping? It's going USPS
to Canada if they let me. UPS takes far too long and costs an arm
and a leg along with your first born child.
Sean
6.0L Tech Folder
Old Aug 18, 2015 | 05:22 PM
  #188
bjk1159's Avatar
bjk1159
While your at it I would check the top o-rings on the injectors. When nipple cup o-rings leak they erode the injector o-rings from the top down.
These were mine after about 3 months.
Old Aug 18, 2015 | 05:43 PM
  #189
Firefighter209
Ok so we "borrowed a friends rail, taken out of a running truck. Put it in to do an air test and its still leaking!
Old Aug 18, 2015 | 05:56 PM
  #190
cheezit's Avatar
cheezit
From what side?
Old Aug 18, 2015 | 06:02 PM
  #191
Firefighter209
Passenger side. Same as the one I took out
Old Aug 18, 2015 | 07:05 PM
  #192
cheezit's Avatar
cheezit
Swap injectors around and retest.
Old Aug 18, 2015 | 07:21 PM
  #193
Firefighter209
Sounds like a plan! Will try that!
Old Aug 18, 2015 | 09:13 PM
  #194
Firefighter209
I guess it helps if you cycle some oil back into it before you retest huh?
Old Aug 18, 2015 | 09:22 PM
  #195
jsm180's Avatar
jsm180
Some good tips here
https://www.ford-trucks.com/forums/1...ole-story.html
And yes, new o rings need oil to seal
