Normal ICP ?
Old Dec 23, 2011 | 01:14 PM
KRDiesel's Avatar
KRDiesel
Normal ICP ?
What are normal ICP and IPR readings at cold idle, hot idle, crusing, and wide open?
Old Dec 23, 2011 | 01:49 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
These are engine warmed up. High idle I believe is to be 2500 RPM.
Cruising would be hard to pin down, too many variables. As for WOT, well, from the operating range, it shouldn't go over the top of the range.
KO is KOEO, Low Idle, High idle, operating range.
Inj. Control Press. (ICP / HPOP)
KO=0 LI=625.5 HI=1400-1450 OR=0-4045 (My low idle runs 585, which seems to be the norm around here)
ICP Voltage (Volts)
KO=0.2 LI=1.0 HI=1.8 OR=.15-4.7 Volts
IPR Duty Cycle
KO=14.84 LI=24 HI=40.60 OR=0-50 %
Old Dec 23, 2011 | 09:33 PM
FSeybert's Avatar
FSeybert
I just did quite a bit of work to mine, so I have been paying particular attention the last couple of days. Cold idle ICP runs about 1800 PSI, I think IPR is in the mid 30% or so. Cruising about 80 MPH, seeing 2200 PSI or so, IPR in the 50%'s. WOT I see 3800 PSI, not sure of IPR position there. Hot idle ICP 585 PSI, IPR 22.5%. Hope this helps.
Old Dec 24, 2011 | 12:12 PM
KRDiesel's Avatar
KRDiesel
Thanks everyone. That is what I was looking for
Old Apr 21, 2013 | 07:39 PM
joejackF250's Avatar
joejackF250
How can I find out my ICP voltage on my scangauge?
Liquid10Rider
6.7L Power Stroke Diesel
Jan 21, 2019 11:07 PM
jed1894
24
Jan 13, 2016 08:34 PM
Curt's05
Nov 24, 2013 08:03 PM
pullinair
Jul 3, 2007 04:31 AM
Mike F250
Mar 17, 2007 09:22 AM
