Help!!! 6.0 nightmare
Old Aug 19, 2015 | 02:27 AM
  #196
Yahiko's Avatar
Yahiko
Originally Posted by Firefighter209
Ok so we "borrowed a friends rail, taken out of a running truck. Put it in to do an air test and its still leaking!
WHAT! Still.
Do what Cheezit says.
When you put the loaner in did the stand pipe come out all the way?
How did all the D-rings look?
BTW I am working on getting that rail ready to send off.
I wanted to clean the oil off so the Post Office does not throw a fit
because of leaking oil or the smell. I'll have to tell you that story
some time. But it's almost all clean I ran out of spray cleaner. Don't
want any dirt in the threads or the O-ring seats.
Sean
6.0L Tech Folder
Old Aug 19, 2015 | 02:49 AM
  #197
Firefighter209's Avatar
Firefighter209
Originally Posted by Yahiko
WHAT! Still.
Sean [IMG]https://cimg0.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/48x48/80-
pyong_raposa_fox_17_42148f79b10282940f51cec764ce99 455b8d603e.gif[/IMG]
6.0L Tech Folder
Umm feeling kind of dumb, we did not cycle any oil back into it before doing an air test. After we did that we did not hear a leak. Tomorrow we will start it and test it out! (I have to have the rail back by 4)
Old Aug 19, 2015 | 08:02 AM
  #198
BBslider001's Avatar
BBslider001
Don't mean to interrupt, but did Sean actually make it over? I thought you were there now? LOL Hoping this works out for you today Firefighter! This has been a long road for you guys.
Old Aug 19, 2015 | 09:53 AM
  #199
Firefighter209
Unfortunately Sean did not make it. He tried but Canada Customs would not allow him entry with his tools. They figured he was here to work even though he was just going to help they considered it "work". I too hope this is the end! It has been a long road. We are on tear down number 7. Cross your fingers!
Old Aug 19, 2015 | 10:40 AM
  #200
cheezit's Avatar
cheezit
Imagine doing that for a living being paid flat rate.
Now we know why auto repair cost so much.
Old Aug 19, 2015 | 05:15 PM
  #201
Firefighter209
Ok got the truck back together started decently. Husband took it for a drive and it stalled while driving and will not start. ????
Old Aug 19, 2015 | 05:40 PM
  #202
cheezit's Avatar
cheezit
Only a few things normall cause that.
Either fuel pressure related are trash in the new ipr are the 2 most common.
What is icp and icpv values.
Old Aug 19, 2015 | 05:48 PM
  #203
Firefighter209
Can't get any values right now. It's stuck on the side of the road. Husband is walking home. He said it threw pressure too low code (cheap hand held scanner) but not sure which code. Will post more when he gets home.
Old Aug 19, 2015 | 06:01 PM
  #204
Firefighter209
It was p2290.
Old Aug 19, 2015 | 09:26 PM
  #205
olfordsnstone's Avatar
olfordsnstone
Injector control pressure too low? (google) Hey, where'd everybody go? Need more popcorn. Firefighter, sorry it didn't work. Stay positive.
Old Aug 19, 2015 | 10:38 PM
  #206
Firefighter209
ICP. .24volt
IPR. 14.84
FICM 48.5 all are koeo
While cranking
ICPvolt bounces between .25 to.54
IPR 84.7
ICP pressure starts at 0 after cranking builds to 242 psi
Old Aug 19, 2015 | 10:41 PM
  #207
bismic's Avatar
bismic
Check the IPR screen
Old Aug 19, 2015 | 10:54 PM
  #208
04badford's Avatar
04badford
More than one thing going on, first I would get the ICPV fixed that way we know the pig tail is not the problem and the volts that we need .85 to start. Then ohm out the sensor to veifi that ICP Sensor is 1 Bad 2 good, ohm and close IPR make sure it moves when asked .
Old Aug 19, 2015 | 10:56 PM
  #209
04badford's Avatar
04badford
ICP. .24volt
IPR. 14.84
While cranking
IPR 84.7
Scratch IPR it's moving , need to fix icpv
Old Aug 20, 2015 | 03:07 AM
  #210
bismic's Avatar
bismic
The ICP volts match the pressure reading (0.24 is zero and 0.54 is 242 psig apprx). But certainly the ICP still might be bad, so if only the sensor is bad, the truck should start with it unplugged.
If the IPR screen is plugged, it will be commanded to close all the way, but will not accomplish the task of sufficiently increasing pressure. Remember - the IPR reading is a commanded duty cycle - not a valve position indicator. On a no-start, there isn't a way to actually confirm that the valve is moving from the duty cycle reading, or even the ICP pressure reading.
