Help!!! 6.0 nightmare
Old Aug 16, 2015 | 05:35 PM
  #151
evan1242's Avatar
evan1242
dang that sucks!
are they not letting him in at all, or just not yet?
Old Aug 16, 2015 | 05:56 PM
  #152
BLADE35's Avatar
BLADE35
Originally Posted by Firefighter209
KOEO ICP is 5.4v
That shows Bad ICP Sensor
I assume its new
So bad wire or Incorrectly wired
Didn't you have SGII???
If so check the code programming
It should be .18-.24v range KOEO
Old Aug 16, 2015 | 06:01 PM
  #153
lupuseven's Avatar
lupuseven
Unfortunately no Canada Customs would not allow him in. They thought he was here to work.
If he can, show customs this thread!
it shows his full intent.
Old Aug 16, 2015 | 06:05 PM
  #154
BLADE35's Avatar
BLADE35
Wish they would do this at the southern us border
Old Aug 16, 2015 | 06:08 PM
  #155
BLADE35's Avatar
BLADE35
Where did the ICP sensor come from
Old Aug 16, 2015 | 06:13 PM
  #156
bismic's Avatar
bismic
Good call Benny. I have seen a mis-configured gauge give a similar reading as well (just something to check).
Old Aug 16, 2015 | 06:22 PM
  #157
04badford's Avatar
04badford
We'll , tell Customs you Own a 6.0 and require to have this much tools to keep her on the road,If that don't work Tell them to go pound sand
Old Aug 16, 2015 | 06:41 PM
  #158
Firefighter209's Avatar
Firefighter209
This one is a used one have another in a box. Will put it in and check voltage.
Old Aug 16, 2015 | 06:44 PM
  #159
BLADE35's Avatar
BLADE35
With any luck it may change it's mind
Atleast your is easy to get to
Was the pigtail to the ICP ever changed
Old Aug 16, 2015 | 06:45 PM
  #160
Firefighter209
Even unplugged I have a hot no start.
  #161
Firefighter209
Pigtail has not been changed to my knowledge.
Old Aug 16, 2015 | 06:59 PM
  #162
BLADE35's Avatar
BLADE35
I understand
But the truck thinks it has high oil pressure if that value is what the PCM is seeing
And if it wiring problem unplug won't help it
Also we could be chasing the wrong system
However you have classic HPO system symtoms
Old Aug 16, 2015 | 07:02 PM
  #163
Firefighter209
Ok just tested the pigtail KOEO with a hand held voltage meter. It reads 5.1. Without the key on it reads .4
Old Aug 16, 2015 | 07:08 PM
  #164
BLADE35's Avatar
BLADE35
That's your problem if you did it correct
I would have to check a wire diagram to be sure
Let me check mine right now key off never checked it that way
Old Aug 16, 2015 | 07:11 PM
  #165
BLADE35's Avatar
BLADE35
Off SGII I can't get a reading key off
That reading is a bust anyway you look at it
