Help!!! 6.0 nightmare
Old Jul 29, 2015 | 11:13 AM
Firefighter209's Avatar
Firefighter209
2006 F350 6.0. New EGR, oil cooler, Hpop with updated STC. New IPR and ICP. Finally got this truck running has a long crank and hot no start, as well as white smoke at idle. Tore down again put new stand pipes and dummy plugs, checked injectors and re-did all of the O rings. Put it back together long crank and again hot no start. Ran a scan IPR % koeo is 14.8% cranking 84.8% ICP pressure while cranking 650 PSI. FICM is 47.5 to 48. Have done an air test with IPR closed can not hear any leaks. Completely stumped. Any ideas?
Old Jul 29, 2015 | 11:23 AM
WatsonR's Avatar
WatsonR
have sync on the crank?
Old Jul 29, 2015 | 11:48 AM
Firefighter209
Yes sync on crank
Old Jul 29, 2015 | 12:37 PM
jswartz84's Avatar
jswartz84
Fuel pressure?
Old Jul 29, 2015 | 02:39 PM
Firefighter209
Not sure will fire after long crank runs excellent until it turns off then poof hot no start. After cooling long crank.
Old Jul 29, 2015 | 03:16 PM
jsm180's Avatar
jsm180
84.8% ICP pressure while cranking 650 PSI indicates HPOP leak or bad pump
Old Jul 29, 2015 | 05:38 PM
cheezit's Avatar
cheezit
Did you double stack ipr screens?
Did the oring get damaged on the updated stc block on install?
Whats vref while it wont start.
Trash in the new ipr from the oil cooler repair, this is really common.
Old Jul 29, 2015 | 06:40 PM
Firefighter209
Just pulled IPR it's clean no damage. STC O ring is good. Not sure what you mean by VREF
Old Jul 29, 2015 | 07:00 PM
dlibson's Avatar
dlibson
5 volt reference.
Old Jul 29, 2015 | 09:06 PM
Firefighter209
I am still unclear of 5 volt reference but can tell you ICP has 5 volts koeo. Sorry new to all of this. Not up on the lingo.
Old Jul 30, 2015 | 01:10 PM
dlibson's Avatar
dlibson
Does it maintain 5 volts cranking, or near to it anyways?
Old Jul 30, 2015 | 03:04 PM
Firefighter209
Yes. The ICP is brand new. My ICP pressure is excellent.
Old Jul 30, 2015 | 03:07 PM
lupuseven's Avatar
lupuseven
Have you inspected the nipple Cups?
Old Jul 30, 2015 | 03:25 PM
Grant-Dieseltech's Avatar
Grant-Dieseltech
Could also be a LPOP problem.
Have you air checked the high pressure system for leaks?
Old Jul 30, 2015 | 03:53 PM
Firefighter209
As stated I HAVE checked for leaks. There do not appear to be any. Nipple cups were done when O ring for injectors were done. New stand pipes and dummy plugs tore down twice to make sure it was done correctly after the hot no start.
