finally! official thread!
then put some kroil on everything.
eat dinner
come back and remove this guy.
put your favorite puller on the pitman arm.
remove this guy.
and then beat it like a red headed step child..i uh i mean hit it really hard?
heres 400$
a tie rod wegde, pitman arm puller, steering gear and the core cost.
i will install tomorrow.
I also have the illustration from the parts catalog in a pdf which would allow zooming in closer, but have lost the ability to attach pdf's to posts or include them in albums, so I'd have to email it to you if you think you need it.
Anyway, the reason for not just posting the pics here is that 9 of them would overwhelm people (trust me, I'm known for creating overload). Besides, you may want to use only a few of them. Good luck!
Dylansfalcone@gmail.com
Thank you! Going for a cool off in the pool then I'm tearing it apart!
Tracked down a trans in pilot va, about two hours away:/
got it taken down, and put back together, phone died while trying to take the bearings out.
which i didnt replace, just the seals.
my bearings and seals looked good, but the main case seal didnt.
Note: i didnt use the orings, or a few spacers.
here she is all cleaned up
me and my friend. we used a big **** pipe wrench and a big breaker bar
heres the front driveshaft and the rubber seal
next remove these guys.
inside of it
the speedo gear and the oil pump i believe
snap ring, and a little pin that will either fall out, or youll have to pull out
washer and bearings pulled
btw, i recommend pulling them off, and laying them in a row, for each side along with taking pictures every step helped me a few times
here she is without the vocer
11 bolts keep them in order
inside cover
my metal magnet
remove this guy, then you will pull this side towards you and turn slightly towards the other side to remove the chain and pull this out of it.
like this
after that tip the case on to its back. other wise this happens.
remove this then
keep them in order
then remove this
this guy is tapered, which i didnt know until i hammered it in...lol
remove this guy, it moves up and down to put the gears in and out such as 4x4 and 4x4 low
then pull this guy
this is the cam that moves the gears
this is the next stop
remove this next..mine was milky becuase i had got water in when i cleaned it
after that, you remove the bearings and seals (which i only replaced gthe seals, my bearings were still good looking. then reverse it to put it back together!
always make sure it will shift through the gears before you put it back together.
and shifts lol ill find out if it works when i put it back in the truck lol
My dad was fussing the whole time I mentioned it saying I know when to pay somebody and when I'm over my head and I tore it down and was like that's it? Psht okay! He ended up stopping by and put most of it back together.
