CREWCAB ONLY
Old Apr 27, 2014 | 05:42 PM
  #91
techningeer's Avatar
techningeer
Originally Posted by BiGGreen350
i would not until the frame body situation is figured out first. it will lead him in the wrong direction if something has been swapped. on an unmolosted truck, thats a good suggestion, on one that is a 95 but titled as a 88 or 89 whatever it is i would dig deeper if you want any facts
^True that.
My suggestion would be to have a DMV Investigator look into the title issue. Make sure you have some proof that you bought it, before you contact them, otherwise they'll hassle you...
Old Apr 27, 2014 | 05:47 PM
  #92
Gicknordon's Avatar
Gicknordon
Originally Posted by GuitarJesus
Chrome? Are they Progressive Hurricanes? I'm guessing they're knock offs, didn't think they made chrome, but they do look good. Wish I had them in 16"
I meant that the chrome is coming off of the stock alcoa's. Not the wheels i have on now.
Old Apr 27, 2014 | 08:05 PM
  #93
breedo99's Avatar
breedo99
Originally Posted by techningeer
^True that. My suggestion would be to have a DMV Investigator look into the title issue. Make sure you have some proof that you bought it, before you contact them, otherwise they'll hassle you...
Its already titled tagged registered and insured in my name
Old Apr 27, 2014 | 08:09 PM
  #94
Crewcabber's Avatar
Crewcabber
See if the axle has a tag on it get the number call Ford and have them decipher it for you. No big deal. You might be able to research it on the web.
Old Apr 27, 2014 | 08:44 PM
  #95
Diesel_Brad's Avatar
Diesel_Brad
That does not mean much if they find conflicting Vin numbers. You could be arrested for having stolen parts
Old Apr 27, 2014 | 08:47 PM
  #96
breedo99's Avatar
breedo99
Im like the 3rd owner that i know of, i think if it was stolen i would know already. Its been all over the US
Old Apr 27, 2014 | 08:55 PM
  #97
Crewcabber's Avatar
Crewcabber
If its titled its legal drive the wheels off of it. What's titled the frame or the cab or did the builder have it verified to use the Vin number from one truck.
Also keep in mind the tag will tell you housing and factory gear ratio. But if it's like my truck it has been re geared. I wouldn't have known unless the p.o. told me. Crack the back cover off of it count ring gear teeth and pinion teeth. There's your ratio. There's another way I think you spin the tire count the revolutions of the tire compared to the revolutions the drive line spins.
Old Apr 27, 2014 | 09:16 PM
  #98
breedo99's Avatar
breedo99
Originally Posted by Crewcabber
If its titled its legal drive the wheels off of it. What's titled the frame or the cab or did the builder have it verified to use the Vin number from one truck. Also keep in mind the tag will tell you housing and factory gear ratio. But if it's like my truck it has been re geared. I wouldn't have known unless the p.o. told me. Crack the back cover off of it count ring gear teeth and pinion teeth. There's your ratio. There's another way I think you spin the tire count the revolutions of the tire compared to the revolutions the drive line spins.
Idk, it has a vin tag in the normal place by the dash, which is whats on the title. Havent look for vins anywhere else
Old Apr 27, 2014 | 09:34 PM
  #99
techningeer
I know here in Iowa you have to have the VIN stamped somewhere on the frame, and it MUST match the cab's VIN.
Old Apr 27, 2014 | 09:35 PM
  #100
breedo99's Avatar
breedo99
Ill check that out, truck came from tennesee or kentucky originally i believe
Old Apr 27, 2014 | 10:23 PM
  #101
techningeer
About the VIN on the frame (Info below is for a late 70's truck, but it will give you an idea of what to look for and where):
In addition to the V.I.N. on the driver's door data plate, the number is also stamped on the frame in two different places, both on the topside of the right frame rail. The first one is in the engine compartment, just below the alternator on two-wheel-drive pickups or just behind the front axle on four-wheel-drive pickups.
The second number is stamped just under where the seat would be located. You'll likely need a flashlight and small mirror to read this one.
These frame stamps are usually hard to read, so be sure to grab a wire brush and some rags to clean the grime off.
Old Apr 28, 2014 | 04:41 AM
  #102
Diesel_Brad
That is NOT true. If YOU are in possession of stolen property no matter of who owned it 1st, YOU are liable
Old Apr 28, 2014 | 08:10 AM
  #103
Crewcabber's Avatar
Crewcabber
They have to prove he had prior knowledge that he was receiving stolen property. Give it up. The guy asked about his rear end. Not a lecture on stolen property.
Old Apr 28, 2014 | 08:26 AM
  #104
Bob Gervais's Avatar
Bob Gervais
This is why I love living in RI. No titles for anything 2001 or older, no VIN checks either, and they couldn't care less where it came from, or what parts are on it.
Old Apr 28, 2014 | 10:13 AM
  #105
techningeer
It's not a lecture: we are simply trying to help him resolve an issue that needs to be resolved sooner or later... Title issues and possibly stolen vehicles are NOT something to be taken lightly.
