POST MOD ISSUES - HELP
Old Jan 31, 2014 | 09:41 PM
  #121
lazyadt's Avatar
lazyadt
Nothing? Ok.
Old Jan 31, 2014 | 10:29 PM
  #122
BLADE35's Avatar
BLADE35
HIGH IDLE MOD
#1=DIESELSTOP WEBSITE
Howto: 05-06 High Idle (AIC/SEIC/BCP) - Diesel Forum - TheDieselStop.com
#2=FLEETFORD PDF LINK
http://api.viglink.com/api/click?for...38393952348410
Old Feb 1, 2014 | 12:00 AM
  #123
lazyadt's Avatar
lazyadt
Thanks for the links. Those are the ones I used to complete the project. I need help with why connecting the two properly colored wires, starting my truck, engaging the park break and flipping the switch, did not result in a change in idle.
Old Feb 1, 2014 | 12:14 AM
  #124
BLADE35's Avatar
BLADE35
Hard to say
Blown Fuse??? Have you checked with DVM to make sure the wire have what they need??
What method did you try BCP or SEIC
Old Feb 1, 2014 | 10:08 AM
  #125
lazyadt's Avatar
lazyadt
BCP. Didn't test for voltage or blown fuse because light comes on at switch. I guess I will. Is the high idle programmed in? Any chance of my programming being corrupt?
Old Feb 1, 2014 | 10:40 AM
  #126
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Which wire did you use for power?
Keep in mind the Purple with light green is the BCP command wire, the Light Green with Purple wire is the BCP output for an indicator light.
Josh
Old Feb 1, 2014 | 12:24 PM
  #127
lazyadt's Avatar
lazyadt
Easy mistake. But, the write-up states to be sure to not confuse them. I know I got the correct wires. Probably trying to make this too complicated.
Old Feb 2, 2014 | 09:07 AM
  #128
lazyadt's Avatar
lazyadt
Figured it out! The bundle that has the BCP wire also has a wire the same color as the #4 switch, orange/light blue. The actual switch wires are above the fuse panel. Works like a charm now!
JonArmy
Mar 30, 2024 08:00 AM
BrookFutureDieselTEC
Aug 8, 2012 02:12 AM
scameron
May 7, 2012 12:25 PM
pkins
Aug 29, 2009 04:28 PM
pkins
Aug 29, 2009 01:47 AM
