Thanks for the links. Those are the ones I used to complete the project. I need help with why connecting the two properly colored wires, starting my truck, engaging the park break and flipping the switch, did not result in a change in idle.
BCP. Didn't test for voltage or blown fuse because light comes on at switch. I guess I will. Is the high idle programmed in? Any chance of my programming being corrupt?
Which wire did you use for power?
Keep in mind the Purple with light green is the BCP command wire, the Light Green with Purple wire is the BCP output for an indicator light.
Figured it out! The bundle that has the BCP wire also has a wire the same color as the #4 switch, orange/light blue. The actual switch wires are above the fuse panel. Works like a charm now!
