Help save my truck
Now my questions for you guys are this; the truck runs rough upon start up on cold mornings. I mean by rough is it jumps around for at least a minute before it smoothes out. When you get it out on the road, it bucks a little. I have 123,000 miles on the truck and I also run full synthetic oil. I pulled the codes and got P0275 (Cylinder 5 contribution/balance) along with a couple EGR codes. Could cylinder 5 injector cause this or could the FICM be going bad. What are some tests I can do to trouble shoot it before I take it to someone. I am trying to save as much money as possible.
<o></o>
Is it a good idea to run the truck with the turbo in limp mode for now? I understand I will have to purchase a tuner with a custom tune to pull the EGR operation out of the computer; is this true?
<o></o>
The more money I can save the closer I will be in keeping my truck.
if you do get it it should smooth out engine operation during cold starts.
do you run 5w-40 syn oil year round not just in winter?
doing the egr delete will cause a few sensors to not read any proper egr flow especially in the late 04's and to the end of 07 models with the 6.0l, ford changed some programming around in the pcm/ecm which always looks for any low or non-existent egr flow and causes the engine to defuel slightly and cause the vgt vanes to lock in a fixed position thanks to your friendly epa idiots.
i recommend you contact eric at innovative diesel, get a sct xcal 2 or 3 tuner to turn the egr off internally this should fix the egr delete issues you are having.
#P0275 Cylinder 5 Contribution/Balance Fault i believe this is a bad injector code so you will need a new injector here.
do you do the proper routine maintenance to the truck, oil/filter every 3k (only refill 13.5qts of oil necessary), fuel filters every 7-15k miles depending upon fuel quality, also drain fuel hfcm at least once a mon.
did you ever send out a oil sample to Blackstone for a analysis?
i would also recommend doing the ccv reroute and a diesel site coolant filter setup also.
i believe my truck has the latest flash. i do the routine maintenance and run syn oil year round, or at least since i bought the truck. changed the fuel filters about 9000 miles ago. i have not drained the hfcm. will check that as soon as i can. i have the coolant filter set up from the diesel site. i have not done the ccv reroute yet.
found a few places online that sell oem rebuilt injectors. good or bad idea?
The latest heat flash would be my advice too, but because you just mentioned you have it (?), I'd blame the cold start issues on the injector and/or the EGR codes.
Oh, are you using fuel additive? If not,- use it!
Just within the last couple of weeks I had the latest flash put in my truck and it helped alot with the rough idle during cold weather starts.
<o></o>
<o></o>
If you suspect a failing or failed injector(s) you could try running some Hot Shot's Secret through it before doing replacement.
Our customers report better performance, no turbo lag, easier starting and more power after just one treatment!
Hot Shot's Secret was designed to address the issue of stiction with the injectors in the 6.0. It was tested by International and found to correct this problem 86% of the time and improved performance for the remaining 14%.
It is completely guaranteed so there is no risk.
See Lubrication Specialties | Diesel Motor Oil | Primrose Engine Oil | Fuel Additives | Oil Additives | Engine Restore| for more info.
ALSO if you are using the truck to haul we recommend the NT Oil Additive. It is a tremendous friction fighter that can be added directly to your trans fluid, improving shifting and extending the life of transmission.
Good Luck in getting this resolved soon. If you have any questions feel free to email or call us.
Best,
Dan
Given the history of this engine: we know that the friction caused by injectors operating at 26K PSI can cause searing of the engine's oil thus causing oxidation to form on the injectors...and thus leading to their eventual malfunction and failure.
We at Lubrication Specialties wonder...how many of the other quirks with the 6.0 don't tie back to this known fact about this engine? Turbo lag is just one symptom, EGR getting crudded up, HPOP failure, injector o-ring failure etc...
Our customers who use our product do not seem to be suffering from the same sort of problems that are reported thousands of times on this blog.
Therefore we feel it necessary when we hear from someone suffering some of these common problems to step out here and make them aware that our product, Hot Shot's Secret, exists and is effective at solving the root cause of the most common problem with the Power Stroke 6.0.
We have customers who have in excess of 500K on their original set of injectors and who do not seem to be breaking down like this. Coincidence?
This is certainly not a scientific test but we are so confident in the effectiveness of Hot Shot's Secret as a preventative as well as a curative that we offer a 100% guarantee.
To those people out here with issues, especially given these difficult economic times, we encourage you to give Hot Shot's Secret a look. We would love everyone to join the 500K mile club with your truck...and as inexpensively as possible!
Furthermore we offer the Blue Diamond product, a FULL PAO synthetic oil (not synthetic blend) along with a bypass filter, guaranteed to deliver top oil performance for up to 50K miles between changes.
If you have any questions feel free to contact us anytime.
Best Regards,
Dan
