POST MOD ISSUES - HELP
Old Dec 16, 2013 | 10:58 PM
  #31
lazyadt's Avatar
lazyadt
What do ya mean HPOP#'s? As soon as I get the OTC adapter, I'll test the HPO system. Need to verify my work on the standpipes and d-plugs anyway.
Old Dec 16, 2013 | 11:01 PM
  #32
lazyadt's Avatar
lazyadt
It will be interesting to see if this is the "FIX" or if he will be asked to post HPOP #s[/QUOTE]
Old Dec 17, 2013 | 06:28 AM
  #33
npccpartsman's Avatar
npccpartsman
I don't think the FICM is the fix to his long/no start with the ICP number he posted, but it's fixing a problem with his FICM.
Old Dec 17, 2013 | 11:05 AM
  #34
lazyadt's Avatar
lazyadt
If my batts are low will that make such a difference in the ICP number?
Old Dec 17, 2013 | 12:27 PM
  #35
npccpartsman
If your truck is cranking sufficiently to start normally the battery voltage won't affect your ICP. You have to have a minimum of cranking RPM's before the PCM will tell the FICM to fire the injectors. 2mPa only equals about 290 PSI which is about 210 short of running.....
Old Dec 20, 2013 | 06:03 PM
  #36
lazyadt's Avatar
lazyadt
Got all my parts and adapters in. Freezing rain all weekend. Maybe get to do some testing on Sunday. I'll let ya know what I find.
Old Dec 22, 2013 | 05:14 PM
  #37
lazyadt's Avatar
lazyadt
Had a couple of hours today. Took off the FICM. My case and connectors look in better shape than replacement. But, the case isn't what matters. Tried to connect my jumper into the IPR without removing turbo. 1/2 hour gone. Finally just tapped into existing wires. No change in air. So, I pulled the turbo and dropped on my hand. Thought it was broke. No such luck. Now, I'm outta time. Wife and kiddo are home. Maybe get back to it tonight. I'll post some pics soon.
Old Dec 22, 2013 | 10:14 PM
  #38
lazyadt's Avatar
lazyadt
Great. Air test showed no leaks. I researched that you need a stethoscope to verify location. I didn't hear anything to even try to locate a noise. Thought IPR was shot after bench test. Put it in for air test, and all air noise ceased. Does that mean my ICP is dead? I was getting low readings.
Old Dec 22, 2013 | 10:52 PM
  #39
lazyadt's Avatar
lazyadt
Left IPR connected for 100 secs. Even made my wife come out and listen. Never heard a peep. Feeling good about my HPOP entire system; STC, pump, stand pipes, d-plugs and IPR. I'll put my turbo back in, connect my new FICM, replace the ICP and call it good. Any tips about something I might be missing would be greatly appreciated. Have a couple days off for the holidays. Hope to wrap it up for the best Xmas present ever! Cost enough. Ha!
Old Dec 22, 2013 | 11:52 PM
  #40
Bonanza35's Avatar
Bonanza35
I'm following your story so please post back on how you did. I have nothing to offer but want to know how you made out.
Old Dec 23, 2013 | 02:24 PM
  #41
lazyadt's Avatar
lazyadt
Here's a few pics of the IPR Harness that I made along with some other shots for your viewing pleasure.
ICP adapter and IPR Socket
NEW FICM
OLD FICM(NO, THEY ARE NOT LABELED BACKWARDS)
AIR TEST ADAPTER
IPR GEN II UP-PIPE
IPR GEN II EGR DELETE
Old Dec 24, 2013 | 07:29 PM
  #42
lazyadt's Avatar
lazyadt
Any suggestions on HPOP system test? Think I'd hear something after that amount of time if I had any leakage. Hope to put it all together on Thursday. I'll update.
Old Dec 27, 2013 | 11:13 PM
  #43
lazyadt's Avatar
lazyadt
IT'S ALIVE!!!! All back together. Only thing I can think is combination of crap batts and FICM dying. ICP perfect, IPR tip top... Haven't heard it in a while and sounds like I got an engine rattle. I'll try to post a video. Let me know how it sounds.
Old Dec 28, 2013 | 12:24 PM
  #44
lazyadt's Avatar
lazyadt
LiveLink Datalog:
Old Dec 28, 2013 | 10:05 PM
  #45
lazyadt's Avatar
lazyadt
I'M FREAKING OUT HERE!!! Went for a 30 minute test drive. Felt good! Came home, fed baby girl her dinner, put her to bed, grabbed a brew to run a few more diagnostics on the truck. WON'T STINKIN START...
Here's the readings... I unplugged the ICP. JUST FOR GIGGLES.
