My block heater cord is wound up in the bumper never the passenger site tow hook. Mine came with a remote start setup from the previous owner so I let it run 5-10 min. I have not owned it thru a winter so I can't comment on the cold stuff.
with the remote start does it let the glow plugs and all that stuff warm up first. or just start it?
IF YOU SCROLL DOWN AND LOOK AT THE ICP PICTURE HE POSTED, I HAVE THE SAME THING EXCEPT HIS HAS BROWN ON IT, MINE DOESNT. I HAVE A PICTURE JUST DO NOT KNOW HOW TO POST IT ON HERE WITHOUT IT BEING A URL?
My block heater cord was zip tied behind the amber lite in the bumper passenger side ,the heater just keeps the oil, coolent and trans fluids nice and toasty the glo plugs will still come on but the dash lite wont stay on that long, If you have cold start may be a Injector try switching oil most run a 5w 40 Rotella or delo synthetic this will help, I ran a revX oil treatment in mine and it helped the stiction of the Injector. the scan Gauge II is a nice tool to watch live Data , Its a must, you need to look at the ICP ICPV,FICM, Batteries, ETC to determine good health, Take a Stroll through the Tech folders and 6.0 Bible and read up on where all these parts are , BTW your Turbo probably a Garret is the big housing on the top back of your Engine that the 3'' pipes are clamped to. happy reading
i think i found the icp sensor. i dont know how to post pictures on here doesnt give me an option. if you know can i email you a picture of the icp i think that is on my truck and you tell me if it is the icp. it looks like the icp just doesnt have the brown piece to it.
It could be I don't have the Numbers infront of me, verify the build date on the valve cover, what makes you think the ICP ?need to monitor data to save you a lot of money, could be something else, just saying.
I got a check engine light and i looked at a ODBII Scanner and it read a code and it said - icp sensor then it said circuit low so i think that is the reason my truck is stuttering.
What was the code? If ICPV volts it could be the pig tail to the senser, this is why we use these Gauges to monitor and process the other parts out. Is the truck stall and surge throttling high?
I am oing to purchase a Scan Gauge ASAP.
Code- P2285
Reading- Injector Control Pressure Sensor Circuit Low
Icp Right?
The truck hasnt Stalled yet but it surges while idling or while driving, it doesnt throttle it way high but it goes up a little, You can surely tell the rev, then down again, and its weird. sometimes it doesnt even do it! Its all real confusing
Icp Right?
Don't get the senser yet, get the Gauge and a pig tail I will walk you through the process look at Riff raff diesel products thay have great prices too
I looked but didnt see a block heater cord on it? it is a 2004.
I didn't think I had one either until I found a cord laying where I usually park... I looked everywhere for where it came from... It is plugged into motor on passenger side near cab below exhaust. I chased the broken section and found it was broke/cut before so I was never able to find the male end which had me thinking I never had one initially.
moral of the story you might have one check the motor and in my case splice more cordage in.
