Codes Icp Help!!
Old Oct 22, 2013 | 11:40 AM
  #121
Guzzo's Avatar
Guzzo
Originally Posted by BLADE35
Smaller cap with the 1/2 drive in it??would be the Upper fuel filter
SOunds like its leaking and may cause Low fuel press in turn killing injectors
can you see it leak with the KOEO fuel pump running
i dont see it leaking, it was in the cap itself. like in the square part itself
Old Oct 22, 2013 | 11:42 AM
  #122
Guzzo's Avatar
Guzzo
what is koeo?
if it is leaking what should i do?
Old Oct 22, 2013 | 11:56 AM
  #123
Money-Pit's Avatar
Money-Pit
take a paper towel and soak up the fuel. If it comes back the cap is likely cracked on top. (someone probably used a ratchet in the square, which can cause the lid to crack. Should only use a socket) Are you sure it is fuel?
KOEO = key on engine off
Old Oct 22, 2013 | 12:22 PM
  #124
Guzzo's Avatar
Guzzo
smelled like it. i will do that. and let you know.
if the cap is cracked... what do i do about that? big issue?
Old Oct 22, 2013 | 12:29 PM
  #125
Money-Pit's Avatar
Money-Pit
If you haven't replaced the upper fuel filter since you bought the truck...your best bet would be to get a Motorcraft (or Racor) filter & cap from Ford....or online. Do NOT use an after market cap or filter. Racor makes the fuel filters for Motorcraft.
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Oct 22, 2013 | 01:10 PM
  #126
Guzzo's Avatar
Guzzo
What is so bad about OEM caps? I will check it, make sure it wasent there from a filter change or something odd. I may not be able to change it for two weeks. Have to work. Will it hurt it?
Old Oct 22, 2013 | 01:20 PM
  #127
BLADE35's Avatar
BLADE35
OEM means ford part
that's what you want
Old Oct 22, 2013 | 01:27 PM
  #128
Money-Pit's Avatar
Money-Pit
OEM = Motorcraft.....OEM/Motorcraft is good! It's the aftermarket ones that are bad. Watch the videos on that link for an explanation.
Old Oct 22, 2013 | 01:39 PM
  #129
Guzzo's Avatar
Guzzo
What does oem stand for? Stupid question I know. What link?
Old Oct 22, 2013 | 01:44 PM
  #130
Money-Pit's Avatar
Money-Pit
Original Equipment Manufacturer = OEM
This link.... Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Oct 22, 2013 | 01:59 PM
  #131
Guzzo's Avatar
Guzzo
i apologize. i was on my phone, it did not show up.
i will check it out now. because all this oem seems a pain in the as$..... but if it helps i will stay oem
wonder how much they are, will check. then maybe order? i havent check my cap yet, will before and after i start and drive.
Old Oct 22, 2013 | 02:10 PM
  #132
Money-Pit's Avatar
Money-Pit
Actually...non OEM in some cases is the pain in the a$$!
Probably looking at about $60 for both fuel filters and the cap. (yes, there are 2 fuel filters)
They suggest using a 1/2" rachet to remove/install the cap.....but don't do it....use a socket
https://www.ford-trucks.com/forums/8...lter-hfcm.html
https://www.ford-trucks.com/forums/8...in-a-6-0l.html
Old Oct 22, 2013 | 02:17 PM
  #133
Guzzo's Avatar
Guzzo
Ok, it seems like I have oem filters. Called the guy that did my injectors ad then did an oil/fuel liter change etc.. For free to!
Why is there two fuel filters? I'm illiterate to diesel I'm sorry! Does it intake more fuel? Seems like I get better mpg then gas!
The table is what. 23 gallons on an 04 right? I thought 29 bit it holds 23. Do I have a reserve fuel tank when my light comes on how much fuel does that mean I have on gallons?
Old Oct 22, 2013 | 09:41 PM
  #134
04badford's Avatar
04badford
The one on the rail under the drivers door is called HFCM, That's your fuel pump and water separator , Check the cap O-ring too sometimes they crack or get twisted up making a non tight situation/leak , don't tighten the cap too tight just snug for no leaks
Old Oct 22, 2013 | 09:47 PM
  #135
Guzzo's Avatar
Guzzo
i will do that, probably tomorrow sometime. have been sooo busy!
