Codes Icp Help!!
Old Oct 19, 2013 | 05:20 PM
  #76
Guzzo's Avatar
Guzzo
im going to try and stay out of a bind and get there tomorrow is the coolent really expensive? im down to 80 bucks left this 6.0 has drained me, ( Not for the bad ) just trying to get it where i want it!
Old Oct 19, 2013 | 05:30 PM
  #77
04badford's Avatar
04badford
I hear ya, I think the ford gold was around 20 bucks and 1 gallon of distilled around $2 better to spend 22 bucks than $5000 on a heated blown heads.
you owe me a beer LOL, yea just add a little coolent then a little dist back and forth until Min line ,then run the truck with cap on keep a close eye on the level for a few days to see where its at each time, may have to add or maybe not when you get a chance a little money set aside I think a full block flush is in Order with a new thermostat .
Old Oct 19, 2013 | 05:34 PM
  #78
Guzzo's Avatar
Guzzo
is that important? how much is that generally?
i will get the coolant tomorrow!!
Is that more important then an egr delete?
i had a code saying i needed to clean my egr i think
Old Oct 19, 2013 | 05:49 PM
  #79
04badford's Avatar
04badford
The beer or the Flush, kidding the Flush is a must around every 10,000 or less if you trailer a lot this will keep the Oil cooler free from plugging up that's where the scan gauge come in to Monitor the oil and coolent temps you don't want any thing higher the 15 degrees spread between the two now when pulling and uphills with a load you will see that so don't get alarmed as long as those temp come back down.
The EGR is simple to pull in my albums you will see my EGR and the flat bars I use to pop it up, you will need 8mm socket extention , twist counter clock wise and use pry bars on both sides pop it , I use carb cleaner and a plumbers flux brush ( don't spray the electrical side or try not to get it in the holes) you can gently open the two discs and brush the soot out, you will find that the Manifold is pretty sooted too chip away the crud and use a shop vac with a short hose of some sort taped to it and Ware your safety Glasses that stuff burns like
Old Oct 19, 2013 | 05:55 PM
  #80
Guzzo's Avatar
Guzzo
i was told $1,150 would get me the kit and the delete because im new to diesels i do not want to mess up my truck! is it hard?
i had to return my gauge as it was broken, hoping to get a new one very soon!
Old Oct 19, 2013 | 06:16 PM
  #81
BLADE35's Avatar
BLADE35
that makes me even more pissed because i have a lift and big tires that stick out as well.. but my window tint? really????
i mean thats pathetic... you live here in west virginia?
im trying to find somewhere the Inspector isnt drooling about my truck.. and driving a prius.... then maybe ill get somewhere. i need some hillbilly as$ **** to by god help me out
hahaha
I live in UTAH MORMAN VILLE LOL
WE have tint law here as well
Don't quote me on this but the front Driver/Passenger doors/windows have to pass a certain amount of Light threw them not shure how much
The windshield can only be tinted so far down from top I (Not Common)
But I think the Rear Doors and windows can be Tinted as dark as you want
Its all tied together with computers Now so if 1 shop fails you cant just go to another Shop without addressing what the first Dinks failed it for
I have now found a Good shop here I use every time No Problems and it would be harder for them to fail for wide tires Now when they have been passing them every year before
Plus they can see I bring this truck to them Every year so they Know its not a Sting from state
Going to be worth asking people you know to find a Good shop there are some real Dinks out there
Old Oct 19, 2013 | 06:22 PM
  #82
Guzzo's Avatar
Guzzo
I just want a throw and go shop that can do it and just wants money. i dont mind buttering the pockets you know what i mean haha!!
but all i have to have is the front windows legal? the others can be black?
Old Oct 19, 2013 | 06:29 PM
  #83
BLADE35's Avatar
BLADE35
I just want a throw and go shop that can do it and just wants money. i dont mind buttering the pockets you know what i mean haha!!?
Well those Indy Shops are the worst IMO
Unless you taking a Stock Vehicle to them
The State seams to watch them Close especialy if they have been Busted in the Past for Fraudulent stuff they get busted to many time they Lose there License
That's here in Utah
What the rules are where you are at I have NO Idea
You should be able to get on a State Website and be able to Veiw all the Rules that pertain to that State where you Live!!
You should be able to google search your state for safety inspection Laws
Each State has its Own Laws Like in Nevada you can Tint all windows Black I believe the Windsheild maybe an Exception to that but that's Nevada
Old Oct 19, 2013 | 07:10 PM
  #84
Guzzo's Avatar
Guzzo
Well the BEER Of Course!
Old Oct 19, 2013 | 07:19 PM
  #85
BLADE35's Avatar
BLADE35
What are you Flushing every 10K Miles?????????? BEER LOL
BTW I use the 2 bar method works Great
makes it so it comes out evenly its a Tight Fit so if gets cocked just a Hair to one side or the other its in a Bind and you will fight it
Old Oct 19, 2013 | 08:26 PM
  #86
Guzzo's Avatar
Guzzo
what all do i have to disconnect/ take off to get to the egr? where is the egr located? if it is simple i will do it myself, if not then i suppose ill pay for it?
egr delete simple too?
Old Oct 19, 2013 | 09:32 PM
  #87
BLADE35's Avatar
BLADE35
I thought your truck was running Good Now???
EGR is easy to get out
the EGR Deleate is abit more involved and depending on if you have emissions testing where you live may complicate things
here is a Pic of the EGR Valve its got the wire harness unplugged in pic
Old Oct 19, 2013 | 09:34 PM
  #88
BLADE35's Avatar
BLADE35
here is how far you must go to get the EGR Cooler out
Its the Long round thing with the Short orange hose on it your may look different depending on the Year but its in the Same location
Old Oct 19, 2013 | 10:03 PM
  #89
04badford's Avatar
04badford
Sorry Guys ,there was a motorcycle crash on our corner, the guy hit the loose gravel and down he went ,he's scrape up pretty good but walked away I stayed there with the Guy gave him water and sat him down Even help load his bike in the back of there truck. where was I 10,000 flushes after drinking to much Beer no that was'ent It
Old Oct 19, 2013 | 10:11 PM
  #90
BLADE35's Avatar
BLADE35
Did you offer him a Beer??He probably needed alittle Pain killer LOL
Glad he is alright
