Cannot locate ICP Sensor ?
Old May 12, 2012 | 11:11 AM
bebeard's Avatar
bebeard
I have searched the threads, but cannot located the ICP Sensor on my 2004 f250 superduty.
Any ideas? can anyone point me in the right direction?
Thanks,
Brook
Old May 12, 2012 | 11:22 AM
ul37's Avatar
ul37
If its not in the passenger valve cover its behind the Turbo next to the IPR Screwed into the H/P cover.
Joe
Old May 12, 2012 | 11:49 AM
bebeard's Avatar
bebeard
What is the H/P Cover?
What Passenger Valve Cover? what does it look like?
Brook
Old May 12, 2012 | 12:26 PM
cartmanea's Avatar
cartmanea
H/P = high pressure oil pump cover, located under the turbo.
Passenger valve cover = exactly that, the valve cover on the passenger side.
If you don't know what a valve cover is, why are you looking for the ICP sensor?
Old May 12, 2012 | 12:31 PM
bebeard's Avatar
bebeard
Just asking questions. isn't that what the forum is for ?
I would consider that a Fender Well Cover, but that is my opinion.
If you want to mock me please don't respond, I am here asking questions like anyone else.
Brook
Old May 12, 2012 | 02:13 PM
bismic's Avatar
bismic
Page 61: Electrical Components
The valve covers being referred to are the steel covers over the valve train - they run parallel to the valley of the engine.
An 04 could have it in either location.
Here is the location for an early 04:
Page 11: Component Locations
Ford Truck Enthusiasts Forums - bismic's Album: IPR and ICP - Picture
Here is a location for a late 04:
Here is a pic of the sensor.
As an FYI - the 6.0L bible is a great resource to go over thoroughly - it will give you tons of info.
Old May 12, 2012 | 02:33 PM
bebeard's Avatar
bebeard
thank you!
I just took off the heat shield the HPOP but didn't see the ICP Sensor... Any suggestions?
Thanks,
Brook
Old May 12, 2012 | 04:28 PM
bebeard's Avatar
bebeard
at a loss...
ok... don't know where else to look....
I took off the heat shield .... took out the wheel well cover ... can't find it... if anyone has any other pics or anything that might help please let me know..
Brook
Old May 12, 2012 | 07:32 PM
bismic's Avatar
bismic
If it is a late 04, you don't take the wheel liner out, just look below the hot side (metal) CAC (Charge Air Cooler) tube. You can also locate it by looking under the alternator and then over a bit (towards the firewall) - on the passenger side valve cover. As in the pic above it is close to the glow plug control module (GPCM).
If it is under the turbo, then you need to read the threads in the Tech folder on removing it (one thread is on removing it from underneath and one is on removing it from to top by first removing the degas bottle, then the FICM).
I don't know how else to help if that doesn't do it.
Old May 12, 2012 | 10:01 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Look at this picture. From the front of the truck, look under your alternator. On the valve cover. See the little brown colored sensor right at the bottom of the picture. If that isn't there, it's under the turbo. Which you can see in the second picture. (which I got from here: Powerstroke 6.0L Technical Intro Manual )
tyrantsparky
Apr 8, 2013 10:07 PM
troys68
Apr 29, 2002 10:03 AM
