Codes Icp Help!!
Old Oct 19, 2013 | 03:48 PM
  #61
04badford's Avatar
04badford
At the end of post # 57 the air sound double check the Degus bottle cap do you see white puke around the cap? it could also be whats called a Turbo fart, the Thump sound on the floor board is the Blend door closing, the first two would make a air sound or tea kettle sound.
Old Oct 19, 2013 | 04:12 PM
  #62
Guzzo's Avatar
Guzzo
Which is the DeGas Bottle?
So i went to get my truck inspected today and was turned down because of my window tint. its a little to dark and $1000 so its not going anywhere
freaking west Virginia laws!
Stupid people with their stupid rules....
hopefully monday i find or can pay off someone to just give me a damn sticker!!!!
Old Oct 19, 2013 | 04:33 PM
  #63
04badford's Avatar
04badford
the coolent bottle is called Degus, check the cap , ford has a upgraded cap don't know if you have the new one? also If to much Pressure or things going on the degus will spew white chalk looking stuff out of the cap, Just checking something from post 57 with the air noise you hear also the level of coolent in the degus makes a big diff
Old Oct 19, 2013 | 04:37 PM
  #64
BLADE35's Avatar
BLADE35
Ya I hear ya Makes you Pissed
When I first got mine the dealer did it first then next year wasn't required then wife takes it to a Jiffey Lube here and they Fail it
it had a Lift and bigger tires well they said I needed Feder flares cause the tires stuck out to Far
What was NOT much at all
I see Trucks Without fender flares with Tires that STick out Much Much Farther then Mine do
My wife said she could hear the guys in the Jiffey lube talking to the tech saying to him your Not reallu going to fail him for that are You?? they didn't stick out to far past fender Well he Did Fail it
That Little SOB was Jealous of my truck and couldn't afford on on his Jiffey Lube wages
I have never used a Jiffey Lube Again and Wont ever again
Talk to dealer asked them what shop they used to get it to Pass the First time so I find out and take it to them Well they Fail it Now I ask why well since first Douch Bag failed it for that they had to fail it
Go back to dealer say WTF they end up giving me those Little Fender Flares the crome ones on it Now take it Bake and Second shop Passes it
The Little Fender flares Did hardly make any Diffrence at ALL But they was Free and they was able to pass it
I know the Guy at the First Jiffey Lube wanted me to go out and Get those Fender flares that are 600-1000 Buck or whatever
It was Intentional what he Did they didn't stick out that Far at all and these Chrome things I have Didn't stick out any more then 1/2-3/4 of an Inch They was Basicaly Point less
The second shop just needed to see a change in order to pass it I had a Long talk with the shop owner that day he told me that the State does stings on it from time to time He Agreed the First SOB was out of Line to but there Hands was Tied since he put it in the computer it failed
Makes you made as Hell
you know if it was there ride it would be Passed or even if you went to a Different shop it would have Likely Passed
Since then I have found a Different place to inspect things and Havent had a Problem unless Legitimate stuff Fails like Brake pads are worn or Tail light out and Im fine with that
Old Oct 19, 2013 | 04:39 PM
  #65
Guzzo's Avatar
Guzzo
If you are talking about the tannish looking bottle that if i was looking from the front of the truck would be drivers side in back on top? looks like it
barely has any fluid in it.
should i add some? no white chalkiness..
What kind of coolant do i need to add?
Old Oct 19, 2013 | 04:43 PM
  #66
04badford's Avatar
04badford
is the coolent at the min line? and what color is the coolent?
Old Oct 19, 2013 | 04:45 PM
  #67
Guzzo's Avatar
Guzzo
that makes me even more pissed because i have a lift and big tires that stick out as well.. but my window tint? really????
i mean thats pathetic... you live here in west virginia?
im trying to find somewhere the Inspector isnt drooling about my truck.. and driving a prius.... then maybe ill get somewhere. i need some hillbilly as$ **** to by god help me out
hahaha
Old Oct 19, 2013 | 04:46 PM
  #68
Guzzo's Avatar
Guzzo
no the coolant is at the ( oh ***** looks like you are about out ) line which is imaginary and is pretty much the bottom.
Old Oct 19, 2013 | 04:50 PM
  #69
04badford's Avatar
04badford
Color? red, green, yellow gold
Old Oct 19, 2013 | 04:55 PM
  #70
Guzzo's Avatar
Guzzo
i would think yellow or gold. i cant really tell there isnt very much left.
what do each of those colors mean? i will go check and check back.
Old Oct 19, 2013 | 05:00 PM
  #71
04badford's Avatar
04badford
well if you have cat ELC red I think, you cant mix any other coolent with it , yello/ gold would be ford Gold coolent I hope . when was the last coolent flush? may need to pick up some ford gold at the dealer and a gallon of distilled water don't add tap water always distilled, and get the level back to MIN line.
Old Oct 19, 2013 | 05:02 PM
  #72
04badford's Avatar
04badford
Green is No Bueno for our 6.0 engines
Old Oct 19, 2013 | 05:04 PM
  #73
Guzzo's Avatar
Guzzo
ok so i dont want any green at all..
is red the best?
so one jug of ford gold coolent and 1 gallon of DISTILLED WATER
if i added the red stuff would i use 1 gallon of distilled water?
can i fill it to the MAX Line? or only to min?
Old Oct 19, 2013 | 05:07 PM
  #74
04badford's Avatar
04badford
is red the best?
If its yellow/ gold keep it that way until the next Flush ( don't add red or green) only ford gold for now and yes Min line
Old Oct 19, 2013 | 05:12 PM
  #75
04badford's Avatar
04badford
If in a bind you can use Zerox silicate free make sure its silicate free tho I'll see if I can get you some numbers on that if ford parts dept is closed
