i will do that, probably tomorrow sometime. have been sooo busy!
That's a good thing, In your Spair time hahaha , read thru the Tech folders there is really good info there , that I need to have you clean up senser wise, also all around great info for the 6.0 Owner the 6.0 bible is a good start to get familiar with the Engine and all the componets. Again always use OEM .
always OEM!
check!
6.0 bible!
Check
All the other stuff i learned!
check!
