Few questions
Old Oct 22, 2013 | 07:43 PM
RKCORPS25's Avatar
RKCORPS25
Few questions
I believe I have an early 04 6.0.
1. Do I have an EBP sensor if so where is it located.
2. My turbo looks like it is dented in the rear cover of it no idea how it happened but is that normal.
3. The ICP sensor is that something I can take off and clean. If so where is it.
4. Is the turbo something I can take out and clean it will be my first time but I think I can do it, about how much time should I plan for this.
Thank you
Old Oct 22, 2013 | 07:51 PM
jswartz84's Avatar
jswartz84
First we need to know the build date of the motor
Old Oct 22, 2013 | 09:03 PM
RKCORPS25's Avatar
RKCORPS25
Ok I am going to try finding it I looked on the ficm but the sticker is missing where else should I look
Old Oct 22, 2013 | 09:19 PM
99ExpyProblems's Avatar
99ExpyProblems
If it's not here (see yellow circle): Yours is an early model and it's on the back of the motor under the turbo.
Old Oct 22, 2013 | 10:06 PM
bismic's Avatar
bismic
They all have EBP senors. If yours is an 04 with an 03 motor, then chances are very good that your truck has been flashed to take the EBP sensor out of the control strategy.
Early 04 motors have the ICP under the turbo instead of on the passenger valve cover. The ICP is better off replaced rather than cleaned. The connector is a common fail point also.
Most folks can handle removing and cleaning the turbo, although it can be a pain. Instructions are in the Tech Folder.
RKCORPS25's Avatar
RKCORPS25
Thanks I will be checking that first thing in the am.
Reaper76
May 10, 2016 02:23 PM
Mich6.0
Jul 28, 2012 01:53 PM
SwanyRiver420
Dec 14, 2010 06:33 PM
sbowling79
Mar 2, 2010 05:01 PM
2005 Ford
Sep 8, 2006 09:43 PM
