Bleed ford until hpfp failure
Old Aug 6, 2013 | 10:15 AM
  #181
2horses's Avatar
2horses
So what's your point, Powerdude?
ETA - never mind, I don't really care............
Old Aug 6, 2013 | 11:49 AM
  #182
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by Powerdude
So, corrosion or misuse, which is what Ford is hiding behind to make the customer pay for HPOP faiures (gas in diesel tank, water in biodiese), etc. could cause a denial of the insurance claim as well.
With almost any warranty - and insurance, they can allege misuse, one of those things is fuel quality, where Ford/other company can easily state the fuel is out of spec, and tell you to pursue the issue with the fuel supplier. Both companies stone wall the end consumer, until they can't be bothered pursuing it.
Old Aug 6, 2013 | 06:07 PM
  #183
Powerdude's Avatar
Powerdude
My point is that if you really want peace of mind, in case the HPOP ever blows up and takes your entire fuel system with it, you should do one of two things, possibly both.
1) Put in a high quality filtering setup, that can filter particulates, possibly including a grenaded HPOP. See here http://www.dieselsite.com/dieselsite...separator.aspx
The owner had the same HPOP failure happen to him as well, plus it's a better fuel/water separator than the Ford system. Note: I have no personal or financial interest in this.
2) Change the HPOP out every 50-60k miles, before it spits out a bunch of diamond monofilament shavings (from pump cylinder coating). Drop the tank, 976 bones later you're done. Either do it yourself or pay for the labor.
Ford High Pressure Oil Pump / Injection Pump Powerstroke 6.7L - ForDiesels.com
At this point, it's pretty evident that the HPOP is a WEAR item, not a life of the truck product. Change it like you would a timing belt to protect your investment beyond 100k miles.
US fuel does not meet Bosch fuel pump specs, and will never meet those specs. Refiners and the EPA do not give rats behind about you or your hard earned money.
Insurance policies can be denied. The above two steps cannot be denied, because the equipment will be yours.
Peace of mind is priceless.
Old Aug 6, 2013 | 07:05 PM
  #184
Firekite's Avatar
Firekite
Powerdude, you keep saying "HPOP" but I really think you mean HPFP. Right? What does the oil pump have to do with any of this?
That's pretty cool. Thanks for sharing!
Old Aug 6, 2013 | 07:30 PM
  #185
2000silverbullet's Avatar
2000silverbullet
Ford will definitely deny your claim should you show up with HPFP problems and that hanging under your truck (whether it's the result of it or not, up to you to prove it).
Just sayin'....
Old Aug 6, 2013 | 07:52 PM
  #186
Tom's Avatar
Tom
At this point it's pretty evident that you are using some pretty funny logic in your declarations. HPFP failures have been few and far between, and there is NO common condition around their failure that I've ever seen other than the likelihood of a bad tank of fuel. If you were right high mileage folks like NEMOTORCARS or ruschejj would have gone through two or three of them by now.
But they haven't. And you're selectively processing information in order to further your point which has little basis in reality at this point in time. I don't know what this will look like five years down the road, but you're making lots of grandiose claims without any data to back them up.
Old Aug 6, 2013 | 07:57 PM
  #187
BigF350's Avatar
BigF350
FTE Emeritus
The main issue with the HPOP, IMHO, is it uses the fuel to lubricate it. If there are issues with the fuel, it will cause issues with the pump through lack of lubrication, and we have seen what happens to the engine when the pump fails...
Running the pump dry/having water in it/the fuel itself not having enough lubrication could all be causes of this. If the fuel was fine, I would assume/hope that the pump would last the life of the engine.
I know VW did a service action on their TDI's which have a similar pump (the 4.1) that were experiencing failures - and that was modifying the tank inlet to prevent the owner putting regular gas in it... which they said was what was causing a number of their pumps to go out. I personally thought that was a pretty poor excuse - because if you put gas in a diesel, you will probably have an engine block with external rods before your fuel pump goes out.
Old Aug 6, 2013 | 08:00 PM
  #188
_red rocket_'s Avatar
_red rocket_
Just sayin'....
Only takes 15 minutes to install
Old Aug 6, 2013 | 08:31 PM
  #189
Firekite's Avatar
Firekite
Surely you mean HPFP. Right? I don't think fuel lubricates the oil pump.
Gas in a diesel tank will not run well and may just plain not run at all depending on how much gas you have in it. But it also doesn't have the same lubrication properties that diesel does, so if there's enough diesel to keep it running and you try to limp it home, your fuel pumps, injectors, and who knows what else will likely be toast.
Old Aug 6, 2013 | 08:53 PM
  #190
CornTruckDriver's Avatar
CornTruckDriver
Has anyone ever used 2 cycle oil in their fuel. They don't want you to use your old motor oil, filtered. How can these things have not enough lubricity?
Old Aug 6, 2013 | 09:07 PM
  #191
CornTruckDriver
Id like to get rid of the separator and replace it with something better. There have been a few cases of the tires throwing stones and busting it causing lack of fuel. There is a spot where I use to cross a brook on the farm that the brook has cut a gulley and its been that way for decades. We call it the Cross the Bridge Lot because in the horse drawn equipment days there was a bridge there. My regular cab trucks and big trucks go in and out without a problem but the long wheelbase trucks settle down on the frame there and go through but the uneven terain makes a busted plastic separator likely. To much plastic critical parts on these trucks.
Old Aug 6, 2013 | 10:18 PM
  #192
Chad149's Avatar
Chad149
Do you have a buddy named rickatic?
Old Aug 6, 2013 | 10:35 PM
  #193
Chad149's Avatar
Chad149
What engines have you seen this on for me to add to my personal knowledge base? I deal with Mercedes diesels write a bit, probably average one a week with gas in the tank, only had one on the currant V6 diesel that suffered rod damage, but only a slight bend causing a intermittent misfire, but could've easily been worse. A couple of HPFP have bit the dust along the way from gas consumption.
Old Aug 7, 2013 | 05:24 AM
  #194
2ndStroke's Avatar
2ndStroke
The 6.7 is designed to run on ulsd. But, I always run additives, supposed to help with lubricity.
Old Aug 7, 2013 | 06:40 AM
  #195
ruschejj's Avatar
ruschejj
Still going I see. Some people just can't wait for the big issue to be discovered that labels these trucks. People like to talk about 6.0 diesels just so they can make an impression on a total stranger, hoping to come across as wise/knowledgeable/"in the loop" with all the other gurus.
I agree 100% with Tom and 2horses. These fuel pumps are not an issue. The issue is a mistaken diagnosis by a service writer.
My job 1 07/2010 build truck with the original fuel pump has 172,000 miles on it. My stock fuel/water separator has never produced a drop of water in that time. Obviously my fuel doesn't sit very long.....
Carry on, nothing to see here folks.
