My CCSB build
Old Oct 20, 2012 | 09:02 PM
  #121
Diesel_Brad's Avatar
Diesel_Brad
It is basically just my tow rig. I have a 20' deck over tailer for anything Big
Old Oct 20, 2012 | 09:40 PM
  #122
BiGGreen350's Avatar
BiGGreen350
hell of a truck brad, i like everything about it, its got a mean stance too
Old Oct 21, 2012 | 10:14 PM
  #123
Badbeny's Avatar
Badbeny
Nice looking truck brad. I like that you chose the older style tail lights.
Old Oct 22, 2012 | 07:10 AM
  #124
boggerted's Avatar
boggerted
Saw your trucks at OKtober Fest and they really look amazing in person. Great work!
Old Oct 22, 2012 | 07:53 AM
  #125
Diesel_Brad
Thanks guys
Old Dec 5, 2012 | 05:50 PM
  #126
bfowler97's Avatar
bfowler97
wow thats prolly the best built obs ive ever seen.couple questions though,what do you do for a living and how long of a project was this?
Old Dec 5, 2012 | 06:09 PM
  #127
fdude64's Avatar
fdude64
good job brad. this spring im gonna redo a bunch of stuff on my truck, and do a few things I didn't. but again awesome job.
Old Dec 5, 2012 | 06:14 PM
  #128
Diesel_Brad
I am a Union Lineman. (subcontracted out to power companies)
You have to remember, I am Single, no kids, No debt(other than mortgage that unemployment covers) and THIS is my only Hobbie. I dont hunt, fish, vacation, etc. All my money goes into my trucks
I bought the truck 2? years ago.
Been doing little things like the rear spring hangers and shackles the 1st weekend I had it.
Then the bug shield and stock sized tires went along with rear brakes, diff cover and era axle seals.
Then the trans was dropped to take care of bad syncros in 2nd and 5rd. While the trans was out I put in a Valair clutch and SMF. Also put in the S H I T T Y MBRP full exhaust.
Then the truck failed inspection for worn ball joints, seized u-joints and worn brakes, SO BY BY TTB and hello D60 w/ RSK
Gauges also were soon to follow since the previous owner had the chip, but no gauges. After I got the gauges, I realized how hot the truck got so i sent the chip back to get reburned
I left it more or less like that for about a year.
then This past june I decided to take care of the rust. I have been collecting parts since I bought it. Put a used set of fenders and rad support on. A used door and New tailgate. Cut all the rust out of the bedsides and bolted the dually fenders on(little more complicated than it sounds). I was laid off for the end of sept and most of oct so That gave me the time I needed to get ALOT done and basically finish it for the OK truck show the end of OCT
It is "done" for now. I am thinking about ditching the splitshot Cali 120cc injectors and putting in a set of stage ones or Possibly stage 2s w a D66 turbo.Also some E-fuel But I have to do some more research to make sure I can still tow what i want without it gettting to hot. No point in having all that power if I cant use it when I tow(the trucks primary use)
Old Dec 5, 2012 | 06:49 PM
  #129
GuitarJesus's Avatar
GuitarJesus
Now Brad, I've heard of 2nd gear. But 5rd? Is that some mystical gas saving overdrive that only gurus such as yourself ever attain?
Old Dec 5, 2012 | 07:01 PM
  #130
Diesel_Brad
5th gear? It is on EVERY zf5 ever made
Old Dec 5, 2012 | 07:04 PM
  #131
Redneckfordf2502002's Avatar
Redneckfordf2502002
It is also known as Overdrive I think thats where he is confused am I right?
Trav
Old Dec 5, 2012 | 07:10 PM
  #132
Bob Gervais's Avatar
Bob Gervais
LOL, I was thinking the same thing, and you guys missed the humor. 5rd? How's about 5th.
Old Dec 5, 2012 | 07:11 PM
  #133
GuitarJesus
Sarcasm brother. Sarcasm.
Old Dec 6, 2012 | 03:50 PM
  #134
garrett_8's Avatar
garrett_8
Originally Posted by Diesel_Brad
Moog is garbage in the past 10 years, I dont care if it has a lifetime warranty, I dont want to have to do the job 3 times because of an INFERIOR product. And believe it or not, the XRF are cheaper priced.
Did not do an outer seal. All they do is hold IN dirt. I got my axles seals IIRC form Randy's Ring and Pinion or Jeff Bronco Graveyard
i agree with the inferior product to an extent i worked at a parts store if the moog parts still had the brass stamped on the bottom on ball joints tie rods ect they were good but anything else was crap,
Any paticular reason you deceided to go with the dually setup?
Old Dec 6, 2012 | 04:25 PM
  #135
garrett_8's Avatar
garrett_8
btw even tho a dually short bed isnt really my thing, i love the truck
