My CCSB build
Old Oct 5, 2012 | 08:49 AM
  #31
Diesel_Brad's Avatar
Diesel_Brad
guys talked me into it. I'm gonna pull the dash
Old Oct 5, 2012 | 08:50 AM
  #32
Diesel_Brad
Old Oct 5, 2012 | 08:51 AM
  #33
Diesel_Brad
Got some more done.
Closed cell foam down on floor and back cab wall.
All doors now have glass and weatherstripping.
Did the door seal mod.
Headliner in.
Got the carpet in after heated power wash and Purple Power.
Both seats are shampooed and drying.
Swapped the 40-20-40 seats around so now the drivers seat has new padding and cover.
Tomorrow I hope to get rear window in, seats in, and put interior trim back in.
Gonna leave door panels off till windows are tinted
Old Oct 5, 2012 | 08:52 AM
  #34
Diesel_Brad
Dont mind the lighter triangle in the middle. The foam was lighter on the back side and I just happened to glue down that piece like that
And the roof
  #35
Diesel_Brad
Got the hood cut and buffed today along with the cowl.(turned out surprisingly good for the amount of bugs that were in it)
Got the windshield trim on along with the cab lights and visor.
Tomorrow the plan is to cut and buff the fenders, doors and roof
Old Oct 5, 2012 | 08:53 AM
  #36
Diesel_Brad
the truck sanded and buffed today. Not to bad considering the bugs, but O well
Have to put hood, header panel, grill, mirrors on and hopefully pinstripe tomorrow
  #37
Diesel_Brad
Got a couple more things done today.
Hood is on with struts.
Headlights in and header panel on.
Tested my batteries and the one tested out to 17amps Guess 2 new ones are in order. (also ordered 2 new neg cables, my ends are done) Ans my belt moldings are on the way THANKS DONNY
Lower stone valence is in.
Cowl is adjusted.
Jack handle and clips are in.
Went to put bumper on but realized when I sandblasted and POR15ed it, I didnt do the brackets
Old Oct 5, 2012 | 08:54 AM
  #38
Diesel_Brad
Well. i got some pinstripe made up today. It was not quite what I hoped but It turned out pretty good.
I was working with a guy in hopes of having printed vinyl just like the factory had. But the printing shop i was talking with gave me back the "Estimate" today.
Needless to say I was a bit FLOORED to say the least. What do you guys think
3 mil Calendared Vinyl
Perm Adhesive
3 mil UV Lamination
Full Color with Silver Metallic
15/16 Pinstripe
Fender @ 48" = $90.00 Each x 2
Front Door @ 45" = $90.00 Each x 2
Rear Door & Cab Corner @ 8" & 36" = $90.00 Each x 2
Front & Rear Bed @ 12" = $90.00 Each x 2
Dully Fender @ 60" = $180.00 Each x 2
Tail Gate @ 68" = $180.00 Each x 1
Total: $1,260.00
__________________________________________________ ______________
3/4 Pinstripe
Fender Bottom & Front @ 13" & 13" = $90.00 Each x 2
Front Door @ 44" = $90.00 Each x 2
Dully Fender @ 48" = $90.00 Each x 2
Total: $900.00
Invoice Total: $2,160.00
So i went to a Vinal sign shop by me today and had them Cut white vinyl and silver vinyl to the factory specs. It is a 2 layer vinyl but you really cant tell unless you run your finger across it. It was defiantly trying my patients laying down the silver over top the white and keeping the 1/16" gap at the top and bottom. But it turned out pretty good. What do you guys think. O and I have MORE than enough stripe to do the top and bottom all for $100
Old Oct 5, 2012 | 08:58 AM
  #39
Diesel_Brad
Taking her for some window tint
15% all the way around w a 5% brow and chin.
Old Oct 5, 2012 | 08:59 AM
  #40
Diesel_Brad
Tint is done, looks pretty bad ***. But truck stalled at tinters and will not restart Just what I need ANOTHER thing to work on
Old Oct 5, 2012 | 09:05 AM
  #41
Diesel_Brad
Working on the dually bed conversion this week
This is what I am starting with
And FACTORY dually bed for pieces
I bought Arrowcraft Conversion fenders since ford never made an OBS short bed dually
Per their instructions they want you to "just" bolt on the dually fenders like a giant fender flare and leave the original wheel well arch in place. Then cut out the fuel doors bigger for the new filler necks. I didn't like the idea of seeing the original wheel well inside the dually fender so I did away with them.
Marking out where to position fenders
Made this little brush to mark the bolt holes
This is how they want you to bolt on the Passenger and drivers fenders
I said *** that and did this
Some pics of the backside of the conversion fender
O and here is why the inner wheel well arches are BAD
All they do is hold dirt and salt and have NO drain holes, UNTILL it rots your bedside out
Old Oct 5, 2012 | 09:07 AM
  #42
Diesel_Brad
Got the passenger side factory brackets transferred over and bonded in. Also made top brackets and POR15 them. These will be bolted to the skin with the fender bolts and Bonded to the inner structure
O and my Dee Zee cab rack came too
And that is up to date as of 10/5/2012
Old Oct 5, 2012 | 09:08 AM
  #43
Bob Gervais's Avatar
Bob Gervais
Originally Posted by Diesel_Brad
Got some more done.
Is this the mod where you pull some surgical tubing through the hollow part of the door seal to get a tighter fit?
Also, pics of the tint? It's GOTTA look bad a$$ being that dark.
Old Oct 5, 2012 | 09:09 AM
  #44
Diesel_Brad
Yes, surgical tubing.
I'll see if i can get some pics today of the tint since it is not raining
Old Oct 5, 2012 | 12:44 PM
  #45
Diesel_Brad
Got the truck running agin(no quite sure how)
here are the tint pics.
It looks darker than it is, the camera cant pick up the light through the 5%
